Anyone running 4:11 Gears?
Old Dec 16, 2004 | 04:14 PM
FeedVaal's Avatar
FeedVaal
Default Anyone running 4:11 Gears?
Do your teeth rattle at highway speed and is it worth the tire spinning fun in first?
Old Dec 16, 2004 | 04:41 PM
BigBadRed's Avatar
BigBadRed
I have 4:10s in my zr-1. The best mod I ever did to the car. Although without the overdrive, I think it would scary at freeway speeds.
Old Dec 16, 2004 | 04:50 PM
Gordonm's Avatar
Gordonm
I ran 4.11s in mine for a couple of years before it let go. It was he$$ on the highway. I was turning 3500 rpm and barely keeping up with traffic. I put in 3.70s and it was better but still turned a lot of rpms on the highway. About an hour was all I could take. Put in the Tremec 5 speed now I turn 2200 at 70 mph. Life is good again!
Old Dec 16, 2004 | 05:02 PM
Wrencher's Avatar
Wrencher
Default Never again...
I ran them in my '66 GTO and it's just too low for a street car. The thing was killer in a drag race, but I got between 4 and 8 miles to the gallon with the tri-power, and freeways were embarassing! My '64 had 3.70's and that was my favorite gear of all. It ran 12.80's on slicks with a stock RA III 400, built THM 400, and it was still a good street driver. I now run 3.55's in both of my cars and they're fine as I spend more and more time cruising. These are all non-overdive transmissions.
Hans
Old Dec 16, 2004 | 05:06 PM
gerry72's Avatar
gerry72
I'm running a 3.55 in the 72 'Vette, a 3.89 in my '67 Fairlane, and I had a car that I ran a 4.57 with 30.5" slicks but drove on the street with 25" street rubber. The more gear you have, the more motor you need. If you can't run strong to 6,500 rpm and above, a 4.11 will be hard to live with. The engine will rpm too quick and shoot past the power band before you can snap your fingers. Sure, you'll be the fastest thing to the 50-foot mark but that's about it. But, if you do have the engine for the job, they are just part of the overall combination. Rear gears, trans and clutch(or torque converter), and chassis. Any of these out of balance tends to make the car hard to live with.
Old Dec 16, 2004 | 05:24 PM
FeedVaal's Avatar
FeedVaal
Thanks,
You've convinced me to stay with my 3.7 ratio.
Old Dec 17, 2004 | 09:21 PM
1971corvette's Avatar
1971corvette
I am running 4.56s in mine,it makes for lots of funny looks.
My advice is stay with the 3.70s
Old Dec 17, 2004 | 09:33 PM
norvalwilhelm's Avatar
norvalwilhelm
There is such a thing as too much gearing. I pulled the 4.11's and went back to 308's because I was getting beat by everything out of the hole. The tremec's 3.25 first combined with 4.11's gve you about 13-1 out of the hole and I wanted about 10-1.
Old Dec 18, 2004 | 04:27 AM
jimtreber's Avatar
jimtreber
4.11's here and wouldn't trade them for anything else.
Along with 406 and TH400 and 3000 stall.
Too much fun at the stop light.
Old Dec 18, 2004 | 07:35 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
My last ride was a '70 Nova with an L-82 (modded my way of course) and Turbo 400 (blew up a couple of Turbo 350's before upgrading) and I remember it well.
I went from one extreme to the other with it! I ran 3:08's for a couple of years after building the engine and going through transmissions. That car was an absolute highway screamer, and would come close to pegging the speedometer in second gear at 6500 RPM. I used G.M.'s 962 hydraulic cam when I built if if anyone is familiar....
Anyway, time came for a 12-bolt posi and the one I put in it was a 4:11 with Richmond Gears in it. ACKKK
It destroyed the freeway driveablity of the car completely. (remember the Turbo 400 has no O/D)
I saw the guy that bought the car from me about two and a half years later and asked him about my motor and the rest of the car. He said that he's still driving it just like I built it and all is well.
But for the gears. He dropped 'em down to 3:73's right after he got the car from me. :o Because he couldn't stand them either!
Old Dec 18, 2004 | 03:19 PM
lyndave75's Avatar
lyndave75
Lots of fun in town, but I stay away from the freeway.
Old Dec 18, 2004 | 08:01 PM
C3 Stroker's Avatar
C3 Stroker
Anything less than 4.11's & you wont be satisfied as far as performance goes..... you make your compromise as to how you use your car .....I use my TransAm to cruise the freeways.
To Anyone running 4:11 Gears?
