Need help with electrical problem
Old Dec 16, 2004 | 06:44 PM
Live75's Avatar
Live75
Cruising
Default Need help with electrical problem
Battery guage on my 75 does not work.I checked both terminals for current and checked ok. I installed another guage and still does not work. anyone have any suggestions. would appreciate any help.
live75
Old Dec 16, 2004 | 07:19 PM
Z-man's Avatar
Z-man
How do you know it doesn't work? I mean, what are the symptoms? I think if it just sits there right in the middle, that means your battery is OK, right? Maybe your battery is OK and the gauge is just sitting there like it is supposed to...
Old Mar 21, 2010 | 04:44 PM
cb33cb's Avatar
cb33cb
1st Gear
if you still have the battery gauge that you first removed install it directly to the battery and make sure that it works. If this works then you will have to follow the wire in your dash cluster back and see were the open is at.
To Need help with electrical problem
