Wheel torque ?
Old Dec 17, 2004 | 06:44 PM
Gordonm's Avatar
Gordonm
Default Wheel torque ?
Just got my tires and rims back from being mounted. There is no way I was letting them hammer them on with a gun. I am running the TTIIs. What should Itorque the nuts to. I thought I read 70-90 ft/lbs but wanted to check.
Old Dec 17, 2004 | 06:53 PM
SharkPilot's Avatar
SharkPilot
That's what I would go with. The stock steel wheels are 75 ft/lbs and I use 80-85 with my aluminum rims.
What size are your TTII's? I'd like to put a set on my '69. Would you post a photo when they're mounted?
SharkPilot
Old Dec 17, 2004 | 07:12 PM
Gordonm's Avatar
Gordonm
I'll post photos tomorrow when I put them on. Just put a front on to see if it rubs. It looks good so far no rubbing.
Wheels are TTIIs 17 X 8
Tires are 255 45 17s
Old Dec 17, 2004 | 07:50 PM
foundvettelifeisgood's Avatar
I do 70 ft/lbs, but they've been tighter...maybe 80 or so. 70 is fine. What 255/45 tire did you decide on?
Old Dec 17, 2004 | 09:25 PM
greyghost79's Avatar
greyghost79
lets see some pics.
what part number is correct for C-3's? TT lists several 15x8
Old Dec 17, 2004 | 09:29 PM
norvalwilhelm's Avatar
norvalwilhelm
I wouldn't go 90 with 7/16 studs, I use 85 with my 1/2 inch studs.
I have stripped stock nuts on the 7/16th studs with 85.
Old Dec 17, 2004 | 11:43 PM
CGGorman's Avatar
CGGorman
75 for me.
Old Dec 17, 2004 | 11:51 PM
toolking's Avatar
toolking
My assy manual says 60 -80 lbs/ft for stock wheels.
Old Dec 18, 2004 | 07:46 AM
Gordonm's Avatar
Gordonm
Thanks guys. I'll stick around 70-75. With the old stell rallys I just buzzed them with the air gun. Not with these wheels
To Wheel torque ?
