Adjusting play in steering
Old Dec 18, 2004 | 10:12 AM
captainmorgan's Avatar
captainmorgan
Default Adjusting play in steering
My 1977 seems to have some play in the steering.
Is there a way to adjust the play in the steering?
Old Dec 18, 2004 | 10:27 AM
jdmick's Avatar
jdmick
If you're talking about the steering box Jim Shea explains it all right here.
http://www.corvettefaq.com/c3/GearAd...-Rev21FE04.doc
There are two adjustments. One involves the big nut around the steering shaft that probably won't need any attention but it doesn't hurt to check it.
The main thing is not to overtighten anything.
Old Dec 18, 2004 | 12:36 PM
GTR1999's Avatar
GTR1999
Read Jim's Papers they're excellant.
Be sure you have the wheel straight and the box centered. I feel it's much easier to set up a box in a bench vise but they can be done in the car. You don't want to tighten the lash screw in the cover much at all and if you do it off center it will throw off the total adjustment for sure - possibly wrecking your worm and pitman.
Gary
Old Dec 18, 2004 | 05:36 PM
captainmorgan
Thanks guy's for the information. I will give it a try.
To Adjusting play in steering
