I'm second guessing my engine HP
Engine Specs: 400 block, 262 XE cam, 462 double hump heads (ported and polished) and 1.5 roler rockers. It had a performer RPM intake, but I changed that to a performer to fit my Q-jet. I don't know the compression ratio, but it ran fine on 87 octane.
I put on 1 5/8" hedman headers and am using the stock HEI distributor with new plugs, wires, rotor, etc. I am using a modified Q-jet carb. I have a 4 speed with a 3.70 rear end.
This summer I had a few problems with tuning the carb and timing. The problem was, my vette never really felt fast (or as fast as I thought it would.) I only drove it 160 km, but put a full tank of gas through it. The engine runs smooth, and doesn't smoke at all.
Any guesses on the actual horsepower numbers on this engine?
assuming 3700 pounds including driver would put you at 230 hp at the flywheel. Sorry, dont know what they weigh
if not, anybody know how you can weigh a vehicle (with driver)
If I'd had one built, I'd always be wondering if the output numbers the builder claimed were real.
Around here, there are a number of unmanned scales where you can weigh your vehicle, one axle at a time. Sometimes you get lucky on a roadtrip and find one. I weighed my vette once with the back full of camping gear. I am not going to
