400 TH Modulator
Old Dec 18, 2004 | 08:05 PM
mikes1973rdstr's Avatar
mikes1973rdstr
Default 400 TH Modulator
Can anyone tell me where the rubber hose on the transmission modulator valve connects to? Thanks
Old Dec 18, 2004 | 08:34 PM
PatsLs1vette's Avatar
PatsLs1vette
It connects to a vacuum port on top of your intake manifold just in front of the distributor.It needs full vacuum to it.you should have a fitting coming out of your intake if not find a vacuum source coming off the carb.
Old Dec 18, 2004 | 09:11 PM
73jst4fun's Avatar
73jst4fun
Look behind your carb, the manifold should have a connection/vacuum port fitting for your trans modulator line right there, follow the metal line to the trans where the small rubber line connects to your trans modulator (if you have auto). Sometimes that rubber line gets dried out from heat and makes a poor connection/looses vacuum to the modulator, I wrapped mine in heat shielding...
To 400 TH Modulator
