battery question
Old Dec 20, 2004 | 12:02 AM
greyghost79's Avatar
greyghost79
Default battery question
bought a battery/charging indicator that plugs into cigarette lighter (from Vector??, i think).
tried it on my 94 chevy p/u. shows 12.5 volts when engine off. 13.5 when engine running so i'm assuming it's reading the alternator charging the battery.
on 79 vette it reads 11 volts when engine off!!!! but 13.8 when engine running.
battery (vette) shows 12.5 volts across the terminals when checked with voltmeter (with engine off).
what would account for the "low" battery reading through the cigarette lighter?
Old Dec 20, 2004 | 10:02 AM
mooneyd's Avatar
mooneyd
The length and guage of wire add resistance and you get a voltage drop. The longer the length of wire the more resistance and the less voltage you get at the other end fron the source.
Old Dec 20, 2004 | 12:13 PM
greyghost79
sounds reasonable but i don't get the same drop when i measure it in my trucks lighter. reads same as across battery terminals.
Old Dec 20, 2004 | 12:38 PM
mooneyd's Avatar
mooneyd
Every car is different, there could be some corrosion in the wiring, ect.
11 volts at the lighter is nothing to worry about.
Old Dec 20, 2004 | 04:52 PM
spikezz4's Avatar
spikezz4
Default Battery Guage
If it is just weak (ie., 11 volts) I would suspect old wiring plus some corrossion. If it gets intermitant, I would suspect a corroded ground somewhere in the circuit.
Spike
To battery question
