will this wheel size fit?
Old Dec 20, 2004 | 01:16 AM
ferndog4's Avatar
ferndog4
Default will this wheel size fit?
Will this wheel size fit an stock 1980? 18" x 9 5 X4.75 +25MM OFFSET
Thanks!
Old Dec 20, 2004 | 01:32 AM
Schmucker's Avatar
Schmucker
No, I believe that has a 5.75 inch backspacing. Stock is 4 inches. You can shoot for something close, but 5.75 is excessive.
Old Dec 20, 2004 | 02:15 AM
timbo79's Avatar
timbo79
I think you will need to get offset trailing arms (rear)
Old Dec 20, 2004 | 03:22 AM
Megawatt's Avatar
Megawatt
Stock backspacing is 4 1/2 " on a 79. I suspect it's the same for an 80. It's measured from the mounting surface of the wheel to the most in board edge of the flange.
http://www.rsracing.com/tech-wheel.html
I mounted 18x9 with 0 offset on all four corners with 275/40/18 tires with no clearance issues.
To will this wheel size fit?
