Good speakers for the front dash.
Old Dec 20, 2004 | 02:23 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Good speakers for the front dash.
Any recomendations while I'll have the dash apart? What will fit?
Len
Old Dec 20, 2004 | 02:26 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Len
Len i put in Pioneers...problem is the dash vibrates and buzzes with any bass....i also put some in my kick panels that i like and they don't vibrate if i had to do it again i would forgo the dash panel ones....
Old Dec 20, 2004 | 02:27 PM
soggybottomboy's Avatar
soggybottomboy
Len,
Just pulled the dash on my 77 yesterday and I purchased the 4X6 pioneers ~$42. These are only two way and I am following up with amp and subwoofers, but there is a 3 way version.
Mark
Old Dec 20, 2004 | 02:31 PM
bobs77vet's Avatar
bobs77vet
Originally Posted by soggybottomboy
Len,
Mark
mark look real close before you put it in to try and firgure out where the vibrations can come from and try and isolate them....mine were the 100 watt version and i'm running a power amp also....
Old Dec 20, 2004 | 02:38 PM
munday's Avatar
munday
I have boston acoustics and THEY ARE GREAT!! pricey but awesome!!!!
Old Dec 20, 2004 | 04:09 PM
soggybottomboy
I didn't think about this but my son did and that's why we purchased the 2 ways for the dash. His opinion was that less bass might reduce the rattle/vibration. One obvious source is between the aluminum grill and the dash pad itself. There are three screws holding the grill down, then the speakers mount to the grill. I put black silicon under that grill for the reasons already mentioned. Thanks for the tip.
Mark
Old Dec 20, 2004 | 04:25 PM
LOTAHP's Avatar
LOTAHP
I have Alpine "plate" speakers that sounded good before the stereo stopped working. They might be outdated, I purchased them about 10 years ago and worked all that time with no problems.
My new speakers are HOOKER , NO MUFFLER design.
Old Dec 20, 2004 | 05:08 PM
John 65's Avatar
John 65
I used the 4x6 pioneers also and had no problems with them up front. Nice sound, good fit, and nice price. I think they were under 40.00 at Wallmart.
Old Dec 20, 2004 | 06:07 PM
kidneyboy's Avatar
kidneyboy
4x6 Pioneers sound great, no vibrations that I've noticed and not too expensive, Canadian dollar notwithstanding.
Old Dec 20, 2004 | 07:43 PM
carhound's Avatar
carhound
J-Head, You have a 69 right? What do you do to put speakers in the dash, cut holes in the dash??
Old Dec 20, 2004 | 07:48 PM
LiveandLetDrive's Avatar
LiveandLetDrive
I'm using Inifinity 4x6" speakers. "Plate" type with seperate tweeter and mid-range. Infinity is pretty much the best common brand of speaker around. Reference is their high-ish line and Kappa is their top of the line.
-Chris
Old Dec 20, 2004 | 08:09 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
No, it's a '70.
Thanks for the input guys. Looks like a standar 4x6 will work.
I just found a pair of 30W Panasonic Sound Pumps II (EAB-692) in the garage. My neighbor gave them to me last summer before he moved away. Claimed they were never used. Still in styrofoam.
Old Dec 20, 2004 | 08:17 PM
lostpatrolman's Avatar
lostpatrolman
carhound, 70 dash has the speaker provisions. You can swap out a 69 dash for the 70 if you really want the dash speakers.
Old Dec 20, 2004 | 11:06 PM
codestar7's Avatar
codestar7
Default 6X9 two ways
Pioneers sound cost effective, Thanks.......
Old Dec 20, 2004 | 11:18 PM
Contrail's Avatar
Contrail
-Chris
Thats what I'm gonna run. Plates love amps though.
As far as the bass problem, there is a "bass blocker" that is sold that will block frequencies below a certain level (ask you friendly neighborhood sound shop) that will get rid of the rattle. 4X6's don't have good bass anyway, they're better for mids and highs.
If I really wanted to spend money I'd get component speakers and mount the woofers in the kick panels and the tweeters in the dash (flush mounted) and run a pair of 10's in the rear, or a single 12.
The 80's hair metal will rock on, at least in my 'Vette anyway...
Old Dec 21, 2004 | 12:05 AM
LiveandLetDrive
No amp here, but soon to be installing Alpine CDA-7894. With 27x4RMS and required amp wiring kit, I think it'll keep those speakers pretty satisfied.
-Chris
Old Dec 21, 2004 | 12:24 AM
cutlass44's Avatar
cutlass44
Boston Acoustics all the way around. there a little bit more but the sound quality is outstanding(as posted before) and the alpine cda-7894 is one of the best decks I've ever owned and is more powerful then most 4x6 can handle(plus it's built in highpass filter can take out the lows to reduce vibrations).
Old Dec 21, 2004 | 12:46 AM
Mr Fanuc's Avatar
Mr Fanuc
What ever you go with for speakers, you may want to try using a small bit of rubber between the speaker and dash to prevent vibration. Just cut a short slice off of a piece of 1/4" ID hose and thread over the screws between speaker and dash. This will keep it from falling out while installing and dampen vibration.
Old Dec 21, 2004 | 01:00 AM
Carl Granquist's Avatar
Carl Granquist
In my '71 I had installed from Ecklers four 4x6 (2 dash, 2 kick-panel) and a 2-**** Kenwood unit (modest power output). All this on good advice, and it's true cuz at speed with roof panels off and headers I only hear the engine anyways! Stoplights are for reality checks.
To Good speakers for the front dash.
