Power Steering Question
Old Dec 20, 2004 | 02:47 PM
Jerpitcher's Avatar
Jerpitcher
Default Power Steering Question
Hey guys,
I've got a 77, and have a question about the power steering. The bolt that attaches the pitman arm to the control valve, does it have an exact amount of torque that it needs? (with a torque wrench)
Thanks everyone!
Old Dec 20, 2004 | 02:52 PM
greyghost79's Avatar
greyghost79
my Haynes repair manual for C3's says:
control valve ballstud to pitman arm nut - 45 ft/lb. torque.
hope this helps
Old Dec 20, 2004 | 02:54 PM
Turbo-Jet's Avatar
Turbo-Jet
hope this helps
yep, GM 42-47 lb-ft
Old Dec 20, 2004 | 03:51 PM
Jerpitcher's Avatar
Jerpitcher
Thanks guys, I appreciate it! I'll go ahead and get the ol' torque wrench out.
Old Dec 20, 2004 | 10:58 PM
Jim Shea's Avatar
Jim Shea
There is one other consideration because of the cotter pin. The spec is 45 ft-lbs torque plus additional torque required to align the nut castellation with the cotter pin hole in the stud (not to exceed 60 ft-lbs). You need to continue torquing to align the nut - do not back off the nut to align things.
Merry Christmas
To Power Steering Question
