Does a 2004r use VSS?
Old Dec 20, 2004 | 04:42 PM
munday's Avatar
munday
Default Does a 2004r use VSS?
Have the tranny under the car and noticed that the 2004r has a 4 prong adapter instead of a screw in speedo.
Is there a cheap conversion for this?
Old Dec 20, 2004 | 05:00 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
this should get you close to the right web site
http://www.bowtieoverdrives.com/cata...AT&CATID=DA1A3
Old Dec 20, 2004 | 06:08 PM
Schmucker's Avatar
Schmucker
No, that four prong hookup is the lockup convertor connection, or in the stock application, where the computer hooks up. It has the standard cable drive. Look in the tailhousing, passenger side. It is probably hard to see if you have the transmission in with the crossmember there as it is right above the crossmember.
Old Dec 20, 2004 | 09:42 PM
munday's Avatar
munday
So if I don't put anything there will it just not lock up? This is my first rebuild so I'm not the most knowledgable I just had a good manual. This is the connecter that ppl have said you can just manually lock up with a switch?
To Does a 2004r use VSS?
