Dash lights
Old Dec 21, 2004 | 07:24 AM
Deep sea vet's Avatar
Deep sea vet
Default Dash lights
I have a 1971 and the dach lights are not working, I looked at the fuses and the fuse was bad so of course I changed it and it blow it again. I'm guessing it is grounding somewere but were. Any info would help. It sucks to drive with a flashlight at night to see the gauges.
Old Dec 21, 2004 | 09:59 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Hmm I might look at the headlight switch first....
Old Dec 21, 2004 | 10:03 AM
Glassbowtie77's Avatar
Glassbowtie77
Old Dec 21, 2004 | 03:31 PM
Todbo's Avatar
Todbo
I feel your pain I had a short on my "trn sig " fuse I had to pull most of my dash , steering column , and finally found my problem over on the pass side , the flasher relay was grounding out on a metal bracket. The only suggestion I can give you..........if you can make the fuse blow under your control , ie. when turn the ignition , or the dash lights , buy a box of fuses and cover the fuse box up with a dark cloth , and try and spot the location of the ground "spark" in a dark enviroment..... I tried this , but I didn't cover the fuse box and I thought the flash was coming from the fuse box well after I pinched my tach wires and broke a plastic piece in my column , I figure I cost myself 2 weeks worth of time.
Old Dec 21, 2004 | 03:36 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
So the headlight switch could cause the dash lights to blow a fuse? It happens to me everytime I turn on the parking lights...my console lights go off because of a blown fuse....
How is this problem solved? Replace the headlight switch or should something be grounded that isn't?
Old Dec 21, 2004 | 05:11 PM
AGVI's Avatar
AGVI
Old Dec 22, 2004 | 07:43 AM
Deep sea vet
Thanks I'll give the head light switch a try to see if there is a short in it
Old Dec 22, 2004 | 08:57 AM
KALAWAY's Avatar
KALAWAY
Get the headlight switch. My daash lights do funny things due to movement of the headlight switch, but they will eventually come on.
To Dash lights
