Vacuum Lines
Old Dec 21, 2004 | 02:31 PM
mrherren's Avatar
mrherren
Default Vacuum Lines
I have several vacuum lines that run no where. Does anyone have or know where i can get a schematic of the vacuum system?
Old Dec 21, 2004 | 02:35 PM
CGGorman's Avatar
CGGorman
Pretty much anywhere Corvette service literature is available...
Old Dec 21, 2004 | 02:56 PM
viperjesse's Avatar
viperjesse
http://www.spectracreations.com/corvette-101/vacuum.htm
Try this site, it will help with the headlights anyway.
JZ
Old Dec 21, 2004 | 03:55 PM
kdf1986's Avatar
kdf1986
I had a simialr question and ended up up buying several Corvette books to help with questions like these. In addition, whenever I do research on the web for items, I end up printing out the pages, and putting them in three ring notebook for reference.
From what I found there are vacuum hoses everywhere. Engine vacuum, headlight vacuum, and other places.
Where are the vacuum hoses that you are asking about. In the general engine area near the carb, or some other place.
kdf
Old Dec 21, 2004 | 04:02 PM
mrherren's Avatar
mrherren
They run up the side of the engine compartment. They appear to be heading for the head lights but stop before the radiator and start by the master cylinder. There's a hand full of them.
Old Dec 21, 2004 | 04:07 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
http://www.corvette-101.com/
Go to the vacuum trouble shooting link on the left and follow it. It sounds like your lines to your headlights are not connected. Do your headlights go up and down when you turn them on, if the car is running?
Old Dec 21, 2004 | 07:26 PM
carl a's Avatar
carl a
there was a web page i had saved that now i cannot find,,, maby somone else can jump in here- it was for the vaccume and related for the heat& a/c vaccume called''chadwick'' i also would like to put this back in my ''favorties''
Old Dec 21, 2004 | 07:32 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
JZ
i've read this one before. i think that it's particularly good.
Old Dec 21, 2004 | 08:44 PM
greyghost79's Avatar
greyghost79
ah, the old "vacuum lines that don't go anywhere" problem. don't 'cha just love these old C3's after Bubba's had his hands on 'em?
Old Dec 21, 2004 | 09:05 PM
rponfick's Avatar
rponfick
Eddie70's diagram appears to be from a 1973 up. I just ordered a complete hose kit from Corvette Central and they include a troubleshooting booklet. Unfortunately, the booklets diagrams are mislabeled. I know my early 69 has a coffee can shaped wiper door actuator, but they show this diagram as a late 69. My early 69 does not have the two vacuum switches attached to the front headlight crossmember that they indicate as being an early 69. Oh well, if you follow the logic, you can eventially figure it out.
Good luck.
To Vacuum Lines
