Where are the option codes on a '69 Vert?
The car is in nice looking shape but underneath it's a mess. The lower and side radiator mounts are rusted through. The lower looks like a bolt on unit but I'm not sure about the sides. The battery box and storage boxes are both cracked up and it looks like the half shaft may have come loose and done that. The frame looks to have some rot as well. I pulled the kick panel off of the drivers side and the body mount is actually loose. The bird cage seems to be fine with little rust. I have some detailed pics if anyone would be interested in looking at them.
It's supposed to be a numbers matching car but I haven't got that far yet. The seller is wanting $17,000 for it but that seem high to me with the rust conditions. What do you guys think it's worth if the numbers match?
Thanks for any help....
Here is a link to the pics;
http://www.thunderracing.com/users/paulf/c3/
The fact is there are no option codes (as a C4 or C5 owner would recognize) on the 69. The option code sticker found under the center console or rear compartment door on newer vettes is called the tank sticker in "C3 speak" and is located on top of the gas tank. It is actually a copy of the buiild sheet from the assembly line. If it still exists it is difficult to get to (drop the tank or lift the body - your choice) and because it has been semi-exposed to the elements for the past 35+years may not be legible.
I don't know what you mean about the option codes in the black book. The base engine was a 300hp 350ci aka L48, the optional small block was 350hp/ 350 ci L46.
Considering the frame rust you mention I would be very hesitant about the car. And I would definitely not pay his asking price.
What would you consider a fair price for a car in this condition, maybe $14,000 or so? Thanks for the help.
Paul
Sounds like this car has many "issues" underneath. Before you get burnt, get somebody who knows these cars to look at it, regardless of the asking price.
There are no option codes listed other than those on the tank sticker. You can check the engine casting number, date, and stamp pad information. Post it here. Chuck
If you want to restore it and keep it, I say it might be OK with a price reduction.
If you ever want to recoupe the $$ spent, then forget it.
You'd have to do a premo restoration and wait many years for it to appreciate.
Why not upload the pictures to the forum server ... then we can
all start to pick it apart. see this: http://forums.corvetteforum.com/showthread.php?t=891758
Oh yeah - there should be a VIN # derivative stamped in the side
of the tranny - driver's side I think.
Here is a picture of the vin stamp on the side of my original tranny for my vette. The last 5 digits should match the last 5 digits in you r vin.
Back in the good old days no one apparently thought anybody would be concerned with the original options on a car if it was around for 30 or 40 years, so the option list was not goven much thought. Also, GM in its infinite wisdom destroyed all records of the original build sheets which would have enabled someone to track his or her car using the VIN, much as can be done with the newer cars through the NCM.
Again, as for the price, I'd be very hesitant.
"The lower and side radiator mounts are rusted through."
The radiator mounts are an integral part of the frame. If they are rusted the whole front clip will sag. The gap between the front edge of the door and the rear edge of the front fender is probably wider at the top than at the bottem.
If this car were a true rarity, say an L89 or L88, it would be worth putting tons of cash into it. But for a small block no. Keep looking, for 17K you should be able to pick up something with a lot fewer issues.
The car is the exact color and year that I want so I'm willing to take what I can get as long as it's not a total heap. Do you think 12K would be a fair price in this condition? Pics coming soon.
Paul
Make sure you don't fall in love with the car and try to keep a rational head. You can very easily fall out of love once you get it home and really dig into it.
My 2 cents.
-Matt
My 2 cents.
-Matt
Keep in mind that over 38,000 69s were made. There are more out there. I love yellow though.
I have some pics of the frame rot that I found when I pulled the body off of my car. If I get a chance, I'll scan and post them. We had to cut out entire sections and patch them in with new metal. I had the resources (read: friends) who were able to fix everything. You'd never know that it was patched by looking under my car today.
Doors don't fit....hood doesn't fit. Lights "sunk" into the surround panel......lots of "issues"
with this car. That car looks like its' hit everything but the lottery. Who is selling this car? Is it a private owner? A dealer? Chuck
