Brake Calipers w/grease?
Old Dec 21, 2004 | 04:11 PM
RMS73's Avatar
RMS73
Default Brake Calipers w/grease?
This morning I removed the rear calipers and upon disassembly I found the area between the front of the piston and the grease seal was packed with grease, dry hard grease. Also in the bottom of each recess for the pistons was a brownish slime. What does grease and DOT3 brake fluid make? The calipers are VBP units but the pistons and seals were standard issue GM items. VBP o-ring pistons are going back in.
Anyway, does anyone out there put grease around the front side of the piston before installing the dust seal?
Roger
