Dash Lamp Sockets '70, Alternatives
Old Dec 21, 2004 | 04:49 PM
jjbobbin1's Avatar
jjbobbin1
Default Dash Lamp Sockets '70, Alternatives
I have a couple of dash lamp sockets that are damaged in my 70. I've looked everywhere I can think of. No luck...It looks like I'll have to buy the entire harness. Does anyone know where I can find dash lamp sockets that ground to the speedo & tach that will work? If not, does anyone have an old dash harness they would like to sell? I can use the sockets.
Thanks,
Joe
Old Dec 21, 2004 | 06:09 PM
Duke94's Avatar
Duke94
I think I might have saved some from my 71' harness when I replaced it. Is 71' the same as 70' if so, I'll go look through my junk box and if I find some you can have them?
Old Dec 21, 2004 | 06:37 PM
lvrpool32's Avatar
lvrpool32
Thanks,
Joe
I had the same problem with my 69, I bought some used ones and they where just as brittle as mine so I went to autozone and you can buy replacement plastic (so a lot stronger) bulb sockets with an 8" connector for $2 each. I replaced all of mine in the end....I was tired of the factory ones coming apart when I tried to pull them out.
Nick
Old Dec 21, 2004 | 07:19 PM
carl a's Avatar
carl a
i would think lectric liminted would have this stuff, then again i couldnt believe they didnt have the ''rivits'' that go on the wire's end for electric connection,,, they have the harnesses they make them,,,so wouldnt this mean they would have the parts???
Old Dec 21, 2004 | 07:41 PM
mrvette's Avatar
mrvette
I THINK I may have some ends you can splice on and solder/tape up the connections...MY recommendations are to just redo the entire thing with a plug to disconnect and reconnect the entire speedo/tach dash panel and save unpluggig every damn bulb in that fiasco while straining to save some part of your anatomy from pain....bag it, some things are just worth changing....beleive me...I had my '72 here for ten years, and finally gave up on the thought I would NEVER pull that damn dash again....
GENE
Old Dec 22, 2004 | 06:55 AM
jjbobbin1's Avatar
jjbobbin1
Thanks, I really need to fix this problem while I have the dash out. I'll certainly be glad to pay for them. I'll need as many as you can spare. I'm pretty sure the lamps are the same for "68 thru '72.
Joe
Old Dec 22, 2004 | 06:58 AM
jjbobbin1's Avatar
jjbobbin1
I've tried Autozone. The one they had in stock didn't work. the metal part of the socket is different. Thanks,Joe
Old Dec 22, 2004 | 07:02 AM
jjbobbin1's Avatar
jjbobbin1
I'm pulling my dash tomorrow. I've had it out a couple other times. Can you tell me a little more about how to wire it using ! plug?
Thanks,
Joe
Old Dec 22, 2004 | 07:04 AM
jjbobbin1's Avatar
jjbobbin1
I've looked at 'Lectric Supply. Saw everything else but no sockets, unless they were attached to a new harness. I'll call them today.Thanks,
Joe
Old Dec 22, 2004 | 07:14 AM
lvrpool32's Avatar
lvrpool32
I think I still have a couple in the garage........I will get you the part number. Its basically a hard plastic bulb socket with 4 metal spring loaded prongs on the end. They dont look anything like the factory ones...but they do work.
Nick
Old Dec 22, 2004 | 10:36 AM
kortensi's Avatar
kortensi
I've got the same problem with two sockets in my 71.
If the autozone ones work, that would be great.
Old Dec 29, 2004 | 09:19 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I think the best fix is to go to a salvage yard, and use the full metal instrument sockets found on early 60's Chevrolets. They NEVER break and fit solidly into the holes. Whenever I see them in a salvage yard I grab them!!
Old Dec 29, 2004 | 10:02 PM
Todd68's Avatar
Todd68
Default Is this what you're looking for?
Corvette Central Corvette Central lists 'Instrument Panel Bulb Socket' catalog part number is 661073 Here is a pic from their website:
I used a couple in my 68. Hope this helps.
Old Dec 29, 2004 | 10:08 PM
carl a's Avatar
carl a
ive seen those at carquest, did you ever call lectric liminited?? then there's ron francis wiring---
To Dash Lamp Sockets '70, Alternatives
