Drag radials
Old Dec 21, 2004 | 09:50 PM
78 Vette's Avatar
78 Vette
Default Drag radials
Any one have a 275/50/15 on a 15 in rally? If so dose it stick out? Looking to get some drag radials and I don't want them to hit on a hard launch. A pic would be great.
Thanks in advance John
Old Dec 21, 2004 | 10:02 PM
C3 Stroker's Avatar
C3 Stroker
I dont have the size you're asking, but I use MT ET Drag radials size 235/60/15 on Cragar aluminum SS alloys which fit nicely....I thought I would need wider tires, but these bite good enough for 1.60 sec. 60 ft. times & 11.8 ET's on my '69.
Old Dec 21, 2004 | 10:12 PM
78 Vette's Avatar
78 Vette
Wow that's the time I'm shooting for. I made 390 on a chassis Dyno (running rich) and my Vette weighs 3600 with me in it so it should go 11.80. Maybe I will get the 235/50/15 drag radial instead. To bad they don't make a 255 that would be perfect.
Old Dec 21, 2004 | 10:13 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I've seen them on a car with 3.375 backspacing and they slightly stick out.. However - with stock backspacing - they shouldn't stick out
Old Dec 21, 2004 | 10:17 PM
78 Vette's Avatar
78 Vette
I think a rally is 4 inch am I right?
Old Dec 21, 2004 | 11:03 PM
nastee383's Avatar
nastee383
That's what I use on my car when I race it. I use 1/4" spacers to keep the tire from rubbing the parking brake cable. They are right at the outer lip.
Old Dec 21, 2004 | 11:07 PM
GrandSportC3
that's correct!!
Old Dec 22, 2004 | 06:42 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Here's the only pic I have of my Drag Radials on my car (275/60/15). They fit fine, but I had to remove the parking brake bracket because it rubbed with the 4" backspacing
Old Dec 22, 2004 | 07:32 AM
Sleper's Avatar
Sleper
Old Dec 22, 2004 | 05:19 PM
78 Vette's Avatar
78 Vette
Thanks for the pics and info .
John
Old Dec 22, 2004 | 09:49 PM
C3 Stroker's Avatar
C3 Stroker
Your set-up seems similar to mine...mine dyno's 375 hp @ rear wheels & 424 ft-lbs. torque....approx 3300 lbs. with me in it...I still need some slight carb tuning, so you should have NO trouble going mid to high 11's with a good launch. Good luck! ( By the way, dont let the tire size number deceive you, the 235/60/15 drag radial is almost the same size as the 255 street radial).
To Drag radials
