AFRs or Canfield heads
http://smokemup.com/bb/viewtopic.php?t=1167
I know they make real nice flow #'s but read what problems some people are having. Other heads may have the same issues I don't know this is just another possible problem to consider.
If its all about horse power why didn't you buy more cubic inches, a set of 18deg., sb-2's, or canted valve heads, some real trick stuff? A 383 is just common stuff now days, about everybody with a hotrod small block chevy has one. I have no connection to AFR and have never owned a set (but might sometime) I just ran across the oiling problem some others had and brought it out for veiwing. I hope "you" and anyone else that have AFR's have "no" oiling problems with them. You mentioned in another post that you knew a HP street engine would use a quart or so of oil in a couple thousand miles, I happen to dissagree on that point, it doesn't have too. If I were planning on buying a set I would appreciate someone letting me know of potential issues, after that I would make my own decision with this in mind. I have no problems with anyone here just had to get this off my mind.
AFR has one of the best reputations of off-the-shelf head companies for the weekend toy (I really don't know about all out race applications as I don't read up on that).
Seeing a thread with someone not happy with their AFR heads is very uncommon. I'm sure I could dig around enough to find some bad comments/experiences about ANY off-the-shelf head company.
Here are some of my comments regarding the other thread:
Later:
Later in the post:
I will also admit that I've pulled my hair trying to find my oil consumption problem, to the point where I have just done a "budget" rebuild of re-ring and new bearings. I should be starting it up any day now and will know soon whether or not the rings were my problem.
Also, I was burning about 1 qt per 600 miles and I was not getting any smoke and I've read about others burning about the same with no smoke. This guy never stated his oil burn rate, but he was getting smoke, so I'm assuming he was burning more oil than me. If this was truely an AFR head problem, you would hear many AFR head buyers screaming about their oil consumption and that is simply not the case.
When I was shopping for heads, I didn't have Canfields on my list. Basically, I started with Vortecs, then TFS 23 degree, then on to AFRs. It also helped that I got my AFRs used, so they were less than the TFS heads.
Anyway, I used Dyno2000 with many different engine setups using the cam specs and head flow numbers to make my determination.
I've heard mostly good about both AFRs and Canfields, so I don't believe it matters that much which you go with.
I also recently read where someone here (best AFR price thread) decided NOT to go with AFRs because of the thread made on the other board.
I'll PM you on my situation as not to hijack this thread.
I've been to the moon and back trying to get my valvecovers to seal properly, there is nearly no oil return rail, so the gasket gets that job. As far as consuming oil? I really couldn't tell you if its burning it, but it sure does find its way out under the valve covers! LOL
Maybe they were having problems when I ordered mine, but the seats were non-concentric, and half the valves failed a simple vacuum test, the seats had to be re-done.
I like mine, would I buy AFR again.? YES
I have AFR 195's on my 383....NO other head produces more HP ....Period!
What I am saying is, which head is giving more bang per buck on a strictly street engine?
For example my old Sportsman II heads actually outflowed my Victor Jr. heads at .400" lift but the Vic. Jr's leave them in the dust after that. But the Sportsman II were a better head for my 355ci which had a .470" lift cam, now I have a 406ci with a cam that opens to over .600" and the Vic. Jr's are a much better head for this motor
I know I'm going to get some flack for putting my faith in DD2000, but I've done many many DD2000 comparisons to CHP mag setups and found that DD2000 was with 5% everywhere in the curve (and 90% of the time was with 3%) compared to CHPs engine dynos. I've verified this for many different cams and heads.
Anyway, here is the DD2000 graph of AFR 190 vs TFS 195
Here are the head flow #s I used
And to keep it on topic, here is AFR vs Canfield
L98: 163cc intake
LT1: 170cc intake
LT4: 195cc intake
LS1: 205cc intake
LS6: ??
LS2: ??
No doubt, the power was increased with each as well, except for the LS6 & LS2.
All said,the 195's have proven to me to be able to feed my 406 to 6500 rpms.In fact while recurving my distributer I ran repeated 6500 rpm blasts in first and second,and discovered my Q-Jet was causing fuel starvation.Once the Holley 3310 was on I promptly blew my transmission.
