HO alternator wire
Old Dec 22, 2004 | 01:00 PM
Tankers's Avatar
Tankers
Default HO alternator wire
Since I put the Spal electric fans on I upgraded to a 135 amp alternator. It says I need to run a 4 gage wire to handle the higher output. On the 71 do I run a wire straight from the battery, or do I splice into the starter wire. Do I still need to run the new wire to the horn relay then over to the alternator. Or is the stock wire good as is and I should leave everything alone.
