oh boy do i have some questions....
anyway, to begin, check this out...
who'da thought there was nice chrome under all that orange paint? i'll be stripping the other valve cover pretty soon and have all the bolts/wingnuts shined up real nice...
on to the questions....
1) how do these calipers/rotors look and what can be done to make them better? should i be looking to buy full replacements cause of the rust? or can they be cleaned/rebuilt?
2) what's this chain doing bolted to the frame there?
3) what goes in here? it's in the front left side of the engine compartment, below the alternator and goes into whatever pulley that is.
4) what on earth is this? looks like a tomato can. i think that tube coming out of it is part of the vaccum system, but i'm not sure.
5) is this bad? what can i do about it? this is the worst spot on the whole frame. there is surface rust on the rest of the frame, but this is pretty bad. i have other pics where it looks like something dragged along the bottom left side of the car....any safety concerns/restoration ideas?
6) finally, the big kahuna..... the brace under the car where the center seat belt receptors bolt to has been rusted away. i got a new one, but noticed this little driveshaft is it? is in the way. is it possible to unhook the connection to the transmission and slide the old piece/new piece in/out?
THANKS GUYS!!!!! maybe i should have broken this up, but i was on a roll....
Not sure about the calipers, surface rust alone is not necessarily bad. Are they leaking or seized?
It looks like someone installed a home made vacuum tank for your headlights. Trace the hoses to see of they go into the headlight relays/actuators.
The chain was likely used to bolt down the engine, in effect making the engine mounts solid.
The frame is in rough shape
Underneath the alternator is the power steering pump. So power steering fluid would go in there. Taking out a drive shaft is not that hard, just MAKE SURE YOU MARK the shaft and the yokes to make sure you put it back in exactly the same way.
above, surface rust is not a good indicator. If it ain't broke ...
On a good note, the upper ball joint has been replaced and the
control arm bushings look to be OK.
2 - yeah - probably to hold the engine down due to a bad motor mount. If not bolted to the engine, then probably fixed.
3 - power steering fluid
4 - I think that is the stock vacuum reserve tank for later C3s.
5 - That is VERY bad - beyond safe bad. They sell repair
sections for that area, but I feel your frame rot goes much
further. Maybe have a welding shop look and see if they think it
is repairable. Might be easier to find a used frame.
6 - Drive shaft disconnects at the rear. Really long extensions
and an air ratchet make the removal easier.
I wish #5 wasn't there. You need to forget EVERYTHING else
and concentrate on the frame. Fixing the other items may be a waste of time.
Good Luck
The way the frame looks in the pic, the car is not safe and needs major frame repair. If the frame was to let loose at this area then the trailing arm is going bye-bye.All the other concerns can be handled with minor repairs or replacement parts.
in the driveway. i want to get it somewhere that i can start really
beginning a body-off project...i don't suppose there's any way to patch
a frame? and i removed all the trim inside and the upper part of the
birdcage looks great....the mounting pillars are rusted out though I
think from looking in the kick panels
Rotted frames CAN be fixed, but there come a point that it is easier
and cheaper to just replace it. When I started my body-off, I was
intent to repair both the rotted frame and birdcage. The more I dug
in, the worse it looked. Finally, I face reality and started searching
for a solution. A local guy contacted me on the forum here. He offered
up a 70 rolling chassis and rear body clip with good birdcage for $1200.
I still needed to repair the rear corners - like where yours are gone.
This is a common area for these frames to rot.
From the sound of your birdcage, it might be repairable. Redwingvette
replaced his rocker channels (lower part of BC). However, your
frame is about as bad as I have seen on a rolling car. Seriously, consider
buying a used frame. I have seen decent ones sell on Ebay for a few hundred.
Check out ZIP (C1-C3 Parts on the left side menu - near top).
they have the frame repair sections, but you will need other portions
fabricated by the welder. It will be costly to repair it.
My old website may be of use to you ... it illustrates vette body and frame rot.
http://webpages.charter.net/davekimtysam/
Not too negative, Paul, if these comments keep him around for NEXT Christmas.
So, I guess I missed that horror story. By community, you mean CF ?
What was his username ?
I was shopping with the Wife today and the front end of a Honda Accord collapsed in front of us in a supermarket parking lot. The driver's wheel just went out at 45 degrees. I have seen this before and too many times. It can get scary knowing these cars are on the road.
This area of the frame is the worst water, salt, dirt and dust and rust collector on the entire car....the good news is that everything else should be in better shape.
Don't worry too much - it can be fixed, just take the body off and start removing the rusted metal ... then decide if you want to have it welded at a shop or by somebody you know or if you want to get a used frame....
I have my own welder (portable) - in case you're close to Orlando...
That looks worse than mine did from below, when I got the body off this is what it looked like
Steve
And what is up with the paint on the carburetor? I have actually never seen someone try to paint a carb before. Chrome yes, but not paint. That is probably the least of the worries at this point. The frame rust should be the highest priority.
kdf
