water pump question
Old Dec 22, 2004 | 11:38 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default water pump question
That hole at top center of the water pump that is always plugged....what's that hole for?
Old Dec 22, 2004 | 11:41 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Many midyears(if not all) actually had a by-pass hose there going to the intake manifold-don't remember what year it stopped, but that hole had an elbow fitting with a rubber hose going to the intake. They used the short leg water pump too like our C3s.
Old Dec 22, 2004 | 11:50 PM
AlwaysWave's Avatar
AlwaysWave
Hmmmm.......so that hole could be used as the temperature sender source? Or heater hose source?
Old Dec 22, 2004 | 11:52 PM
Paul Borowski
Probably, as long as it did'nt protrude down far enough and hit the impeller
To water pump question
