Gauge lights not working...sometimes
Old Dec 23, 2004 | 05:44 PM
Musclecarmaniac's Avatar
Musclecarmaniac
Default Gauge lights not working...sometimes
I decided to pull apart the dash to fix the gauge lights. I got them to work, as I found an unplugged connection and a missing fuse in the fusebox. But they only work when the parking lights are on, not when you fully pull out the switch to activate the headlights. They then turn off again. I was thinking bad headlight switch, but the headlights do come on like they are supposed to. Only the dash lights fail to light up. Ideas??
(I think the previous owner, who failed to mention any of this, knew of the problem due to the "missing" fuse, and the dash lights were already out when I bought the car)
Thanks in Advance!
Last edited by Musclecarmaniac; Dec 23, 2004 at 09:35 PM. Reason: adding year 1977
Old Dec 23, 2004 | 05:47 PM
cchristo's Avatar
cchristo
http://iotech.no/corvette/technical/...tics/index.htm
This might get you started in the right direction.
Old Dec 23, 2004 | 09:34 PM
Musclecarmaniac
thanks a bunch, but I think I might need more trouble shooting suggestions.
I called the old man, (Dads are great) and he thinks it is the headlight switch and the previous owner mounted the gauge's power wire on the parking light terminal instead of the head light terminal. Any electic experts out there in Vetteland know?
Help! I want to finish tomorrow. My C3 dash and interior look like C3PO after he walked in on the Stormtroopers.
Old Dec 23, 2004 | 09:36 PM
Musclecarmaniac
This might help after I get it apart. Do you have it in 1977? Cause it looks different than mine. Thanks!
Old Dec 23, 2004 | 10:25 PM
Older Than Dirt's Avatar
Older Than Dirt
You say the dash lights and the parking lights both operate in the parking switch position? When you pull the switch to headlight operation the dash lights go out, but what about the parking lights, do they go out too?
Old Dec 23, 2004 | 10:48 PM
isosceles's Avatar
isosceles
I had the same problem that turned out to be the HL switch. The rheostat portion of it goes bad sometimes.
I tested it by the following:
You can take a jumper wire from the "ign on" block in the fuse panel and try putting power to one side of the fuse socket marked "inst lights". I had a jumper with a fuse in it and a spade connector on each end. I can't remember if it was the 2 prongs on the right or left side of the instr light fuse holder that I jumped to, but with that set up, the instrument lights would come on when the ignition was on.
When my new headlamp switch arrived, I replaced it and removed the jumper. Now the dash lights work as they should.
Old Dec 24, 2004 | 03:13 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Dec 24, 2004 | 06:40 PM
Musclecarmaniac
Thanks!
I will give it a shot the day after Xmas as it is too cold. Snowed here in Sugar Land Texas 1st time in 15 years!
Any one else want to chime in? Or is everyone in agreement that is the probable cause?
Old Dec 26, 2004 | 08:44 PM
Musclecarmaniac
I took the dash off to get at the switch. I decided to try to hook up the gauge wire to a different terminal and WALLAH! I now have gauge lights. Funny thing is that the HL switch looks nothing like the pics of a 77 HL switch. It looks an older fashioned type, with 4 copper colored terminals on a copper plate. I think it might even be a Ford as it looks kinda like my old 65 Stang's switch. Ecklers says this is what should be in my car:
But it was WAY more simple. Imagine a 3" long" folded copper plate with four terminals, and the switch **** itself. Sounds like the previous owner didn't want to spring for the $12.99 switch at NAPA
Old Dec 28, 2004 | 02:28 AM
EVIL_GRIM's Avatar
EVIL_GRIM
had same problem on my 79, still do to a point. anyways i replaced the switch and somehow got my low beams to work. then my interior lights started working and then all of a sudden it all stopped and no lights (interior or exterior) work except for the headlights. i think i have a bad ground which is causing most of my on and off problems.
To Gauge lights not working...sometimes
