Clutch Rattle?
Old Dec 24, 2004 | 05:37 PM
Taijutsu's Avatar
Taijutsu
Default Clutch Rattle?
I reciently replaced the clutch on my 74 w/M21. Since then the clutch pedal has a rattle in it when in neutral. If I press down slightly, the rattle goes away. Is this a simple adj or something bigger. The clutch seems to have the right ammount of free play. Any ideas? TIA
Rick
Old Dec 24, 2004 | 06:29 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Sounds as though your pilot bushing in your crank is wore out. This will cause the input shaft of the transmission to wobble in neutral making the noise you hear. When you press in clutch the input shaft stops rotating and the noise goes away. Was this exact same thing 4yrs ago on my Blue '68 convertible. Tranny, bellhousing, clutchplate & disc need to be removed. Flywheel can remain on to get at the PILOT BUSHING. Not 100% sure if this is your problem as you describe it, but it's PROBABLY what it is.
Old Dec 24, 2004 | 06:49 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Did you hook up the springs on the clutch rod and Z bar?
Old Dec 25, 2004 | 09:17 PM
Taijutsu's Avatar
Taijutsu
I didn't do any of the work. It does sound like the rattle/vibration is in the linkage, not the disk & PP. How do I check the z bar and spprings?
Thanks much,
Rick
Old Dec 26, 2004 | 04:37 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
There's two springs that attach to the pushrod that goes from the Z-bar to the clutch fork. They attach to the center of this pushrod and one goes to the z-bar, the other the fork. Oh, there is also one other spring that goes from the z-bar to the fire wall on the frame side. This is actually a return spring to help raise the pedal when your not pressing it, probably to reduce wear on the clutch.
Old Dec 26, 2004 | 11:44 AM
PRNDL's Avatar
PRNDL
The 2 little springs (not the return spring) are called, "anti-rattle springs" so naturally one would suspect their absence as a cause for rattling. Good idea to check for them first! May or may not be the actual problem.
http://www.zip-products.com/Corvette...BE133AEFD370E2
Old Dec 26, 2004 | 12:17 PM
Taijutsu's Avatar
Taijutsu
I think you may haver found it. I will keep the forum posted.
Rick
Old Dec 29, 2004 | 08:12 PM
Taijutsu's Avatar
Taijutsu
I think the anti rattle spring is the answer. Could someone post a pic/diagram of the Z bar and springs? TIA
Rick
Old Dec 29, 2004 | 09:01 PM
Todd68's Avatar
Todd68
I just replaced these on my 68 last summer, easy to do. Here's the diagram:
Old Dec 30, 2004 | 05:16 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Check the operating rods for elongated holes.
Thought i had a worn clutch once only to find the linkage was bad. After 25 yrs the clutch operating rod holes had became slots. The clutch would kinda slip into engagement.
Replaced both rods and Z-bar for <$100. Could'a repaired old pieces but plenty of new replacements availible from the vendors and not much $$.
Happy hunting. cardo0
To Clutch Rattle?
