OK, so I have just recently finished installing new 100% leather seat covers c/w new foam. I'm very pleased with how they turned out. I know there is a process where a hair blow dryer or heat gun is used to remove minor wrinkles. I'm a little concerned about doing this. Anyone have any experience doing this and can share some tips?? Will natural heat, in the summer time, remove these wrinkles by themselves??
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
heat is used with vinyl.....not sure whats used w/leather
let them sit in the sun.....and also go look at any new car with leather its filled with wrinkles....sometimes its best to leave good enough alone.....
where did you get them? I'm going to re-do the interior in the spring. I was planning on having corvette central do the whole process, with new foam, their labor seems reasonable (approx $230 for labor). I would love to hear any recommendations from any members.
Got mine from Wilcox. Best price I could find. Good friendly service. Shipped to Canad without any hassels. The product is Mid America coers and foam. I was happy with the quality. They turned out very nice.
I found that Willcox advertises new interior parts on ebay. Search on your year corvette and you should find the items (door coverss, carpet, seats, etc.).
I got my leatherlike from TDL and yes...a heat gun does remove wrinkles from vynal & leather...but only the small ones. Keep the heat gun moving...heat...let cool. Heat...let cool.
Using a heat gun (blow drier) on seat covers will help remove wrinkles.
For goodness sakes use the blow drier and not a heat gun if you have never done this before!
Never, never, never attempt to steam leather seat covers. I know, no one mentioned steam but it's an old interior installation trick to help old foam swell and look good. Vinyl covers on old foam can be steamed and will work to temporarily swell the old foam and make the cover look good. Using steam on leather covers will rot the covers!
Foam, no matter how nice it looks will collapse. The pockets created in the old foam will be hidden by the old cover stretching with the foam. New covers will be tight and show the collapsed area. This will also cause premature seat cover failure. The main place the foam will collapse is in the area where your rear hits it, as well as the area where you side (waist) hits the cover. Both areas will squash down in the old foam! This will create what we term "floppy" area when the new cover is installed. We don't believe in padding foam either. Foam padding glued to the old foam will show when the cover is installed.
Our shop policy here is that we will not install new covers on old foam. We learned this lesson the hard way. Just as soon as you install covers on old foam and have floppy areas. Then the customer looks at the covers and wonders why this happened. When you explain it to them in detail.... We'll now they want new foam installed to make the covers look good.
The only problem with this is that we now have the labor in the installation one time, but now we have it two times. Customers don't want to pay twice for doing an installation and thus the company policy to not install old foam under new covers....
All I've got left tonight is my 2 cents, and I just spent it...
