To Restore, or to Modify?
Old Dec 25, 2004 | 04:00 AM
Lygriek's Avatar
Lygriek
3rd Gear
Default To Restore, or to Modify?
Hello all,
I just aquired a 1982 Collectors Edition Corvette. I got it for pretty cheap as the seller thought it had a salvaged title after a theft recovery many years ago, but it turns out that it just had a replacment Vin Tag, which is affixed to the drivers door jam, the Title is clean.
My original intention was to fix it up however I saw fit, modifying along the way for better handling and power, not really paying attantion that it was a Collectors Edition, with regards to keeping it original. But now I am wondering, would I be ruining a restorable specimen? Does the replacment Vin Tag ruin its chances of being a "Collector"? The car is in fairly good shape, besides needing some weather/moldings and new seats, a little work in the interior, the removal of a class II trailer hitch , and fixing a constant electrical drain that killed the battery.
I am only into ther car for $2500.
Any opinions?
No really, what do you all think?
Lygriek
Old Dec 25, 2004 | 04:50 AM
hunt4cleanair's Avatar
hunt4cleanair
Originally Posted by Lygriek
Hello all,
A replacement VIN will always sound suspicious and will always query a story yet it sounds like you've got a nice Corvette well worth retaining its originality. We see similiar scenarios with C2s and early C3s and the owner is compelled to document the car. Your in luck because the national corvette museum can produce the original build sheet for your VIN that will reconcile with the options on the car. If the build sheet shows 1YY07...that's a pretty tough option to re-create along with the other options.
Than there is the story of a "replacement VIN tag" and how that happened...its not easy to remove a windshield and replace a tag...so how did that happen? The story must sound reasonable to a prospective investor.
So I would work on documenting the car first approach it as tho you're a wary buyer. If you're satisifed work to restore its originality...otherwise mode the crap out of it!
FEDX's Avatar
FEDX
From: A high school diploma fixing what a college degree broke TN
Just my opinion,but if its a rare edition and pretty close to original,I would keep it that way.Sell it as is,or restore it back to stock,sell it and put the money into a non numbers matching vette you can do whatever you want to with without hurting its potential value.Again,just my opinion and
Old Dec 25, 2004 | 04:55 AM
FEDX's Avatar
FEDX
Also do a search here in C3,a member named Platato posted the details of who to contact at GM to get the dealer invoice on your car for free.Maybe a copy of the original invoice can help you document the history of the car in some way.
Old Dec 25, 2004 | 10:12 AM
Paul L's Avatar
Paul L
I think he is referring to the VIN sticker, often removed for paint jobs.
http://www.drdecal.com/store/search....id=127&ccat=63
Old Dec 25, 2004 | 01:41 PM
Lygriek's Avatar
Lygriek
3rd Gear
Well, I know the original owner, well kinda, I aquired it from her son. He just didn't have time for the car and really was not interested in it. The car had been stolen I think twice, the second time it was gone for a long time. Turned out the LAPD had known where the car was but decided to follow it to catch more of the bad guys, in the mean time the vin tags were removed and replace with the vin tags off of a cadilac. I guess we are lucky it was not stripped for parts.
Its been mostly parked for 10 years, non-op. When she was driving it before she drove it everywhere, odometer says 36k, but I woiuld bet its more like 136k.
For now I think I will concentrate on getting it running and driving like original, and keep researching.
Thanks for the thoughts,
Lygriek
Old Dec 25, 2004 | 01:54 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
.... if you think it doesn't handle good enough then upgrade the suspension, if you think it's not fast enough then upgrade the engine....it is your car and you are the one that drives it and who enjoys it.... do what you want....
EXCEPT : 28" wheels and/or a 87" wide aluminum spoiler
Old Dec 25, 2004 | 02:07 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
do what you want with it ..........the title/vin issue will never go away and will detract from the price for someone who is "picky" about those things....or they will use it to "bargain you down"
Old Dec 25, 2004 | 05:50 PM
markdtn's Avatar
markdtn
It will never bring what an unmolested CE will, but the 82 CE is a desirable C3. I would fix it if most of the CE parts are still there. If you don't really like it, fix it and buy something else to cut up and modify. It's still worth considerably more than a "plain" 82 with similar history.
Old Dec 25, 2004 | 06:11 PM
stingr69's Avatar
stingr69
Condition is everything here IMHO. If the car is still nice, you would do better to keep it that way. If it shows a few more signs of wear and tear, you can go ahead and mod it out as desired. Plenty of real nice museum quality CE Vettes out there still so once it starts to get used-up, the extra value drops out of the equation quickly. Take a look at the prices of 78 Pace Cars once they get a few thousand miles under their belt. The price drops down to reasonable real fast.
I think the wear and tear is a blessing in a way. You can do more to the car without changing the value much.
-Mark.
Old Dec 27, 2004 | 02:45 AM
Lygriek's Avatar
Lygriek
3rd Gear
Thanks for all the input, I think I am leaning toward the Slightly Modified route. The wear and tear on the car I realize now is considerable, seats are nearly usless, miles are high, interior is a mess. Body is straight but paint needs to be redone. All the weather striping is shot.
It seams like all the collector badges and stuff like the wheels are in excellent shape. If I could just get it to start... Fuel problems... Injector are firing, spark is good, fuel pump seems to be running... need to check pressure I guess.
It ran fine before the battery died, new battery... no go?
Any wisdom on Corvette quirks regarding this subject?
Thanks,
Lygriek
Old Dec 27, 2004 | 09:04 AM
markdtn's Avatar
markdtn
Look for TwinTurbo. He has considerable wisdom on the CrossFire.
To To Restore, or to Modify?
