engine off vacuum
Old Dec 26, 2004 | 07:12 PM
greyghost79's Avatar
greyghost79
Default engine off vacuum
my distributors vacuum advance holds vacuum with the engine off. even if off for several days, if hose is disconnected from vacuum canister you can hear the rush of air when the hose is pulled off. is this normal?
Old Dec 26, 2004 | 07:24 PM
s car go's Avatar
s car go
No.
Old Dec 26, 2004 | 07:37 PM
greyghost79
any ideas?
Old Dec 26, 2004 | 07:49 PM
ManFromEagle's Avatar
ManFromEagle
If you pull the hose off the carb end does it do the same thing?
If not it's possible the hose is bad. I have seen hydraulic hoses were a flap of the rubber comes loose on the inside and it acts like a little check valve. Just a thought.
Old Dec 26, 2004 | 07:51 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I would guess that the hose is partially collapsed inside forming a sort of check valve...
Old Dec 26, 2004 | 07:52 PM
greyghost79
hmmmm... good question. i'll have to go out and check it.
also, there is a small, thin, disk shaped "filter???" in the middle of the hose. is that "stock" or a Bubba modification?
Old Dec 26, 2004 | 08:00 PM
Bobchad's Avatar
Bobchad
My 77 has a straight run of vacuum tube. Almost sounds like you have a check valve in line.
Old Dec 26, 2004 | 08:03 PM
Twin_Turbo's Avatar
Twin_Turbo
Someone goofed up and installed a check calve in that line, remove it. It is only installed in the vac. ssytem for headlights& misc components (cc switch) and brake booster.
Old Dec 27, 2004 | 03:18 PM
s car go's Avatar
s car go
Where is the other end of the hose connected? Maybe its in the wrong port of the carb.
Old Dec 27, 2004 | 03:25 PM
greyghost79
in the back, next to the brake booster
Old Dec 27, 2004 | 03:27 PM
Missileman's Avatar
Missileman
Vacuum advance for a 79 comes off of the base of the carb (look at your emissions sticker, it will show which side in the front. Should be the pass. side) and goes straight to the advance canister with nothing in between. Sounds like someone put the headlight vac. check valve on the advance line, which is wrong. Effectively it is giving you full advance always, which is great for fuel mileage but difficulty in starting and too much adv. at full throttle means low power and detonation.
Old Dec 27, 2004 | 03:30 PM
greyghost79
emissions sticker is long gone. so you're saying the vacuum attaches to the FRONT of the carb??
Old Dec 27, 2004 | 03:36 PM
i885744's Avatar
i885744
can you take us a picture? That would help alot. Sounds like someone installed a check valve to me too. Remove the line altogether and run a new one and see if that helps, worst that can happen is you're down 50 cents for the vacuum line
Old Dec 27, 2004 | 03:41 PM
greyghost79
i removed it already. can't really tell any difference in the way it runs. checked timing and i've got 12 degrees initial timing. another twenty at idle with or without the check valve in. that doesn't sound right either. any ideas
Old Dec 27, 2004 | 04:20 PM
Missileman's Avatar
Missileman
If you go to an auto parts store website that has the word "zone" in it (forum rules) you can print the vacuum diagram for your year vette. For a 79 with federal emissions the dist. line starts at the base of the carb, in the front, all the way left. It then goes to a thermal vacuum switch (eliminating advance until approx.126 degrees), then to the dist. Your advance should give approx. 16 degrees at 17" vacuum. Since you know the diaphram is good, check that the reluctor ring (can attaches to) moves when vacuum is applied.
The timing specs (also at the website) shows 12 degrees initial for the 225hp, 6 for the base motor. It looks like you are getting some mech. advance, but no vac. advance. You can attach the vac. advance line straight to intake manif. vacuum (nipple behind carb) with no problems if you don't have the original carb.
Old Dec 27, 2004 | 05:51 PM
greyghost79
no, i'm getting vacuum and mechanical.
12 initial (79 L-82). that's correct.
when attaching vacuum hose at idle another 20 for 32.
and another 20 mechanical all in by 2500-3000 (didn't take exact measurement) for total timing of 52. that should be right, no?????
Old Dec 27, 2004 | 07:19 PM
Missileman's Avatar
Missileman
Yes, that is right.
To engine off vacuum
