Bench testing starter?
Old Dec 26, 2004 | 09:54 PM
74FLCONV's Avatar
74FLCONV
Default Bench testing starter?
Having performed all the recommended diagnostic tests in the '74 Service Manual, I removed my starter and tried to get it to spin. The manual is vauge on this procedure.
I hooked up jumper cables from the battery to the starter (positive to battery terminal, negative to starter body) then jumped the battery post to the "S" post. Nothing but sparks.
Is it safe to assume the starter is bad?
Thanks in advance,
D. Ocean
Miami, FLA
Old Dec 26, 2004 | 10:05 PM
markdtn's Avatar
markdtn
Yes, assuming good jumper cables and good connections.
Old Dec 26, 2004 | 10:12 PM
79ls1's Avatar
79ls1
It is probably only the solenoid. If the windings were fried, you'd know it because what you described would creat a dead short if they were and it would have a smell of burned bacon. You can change just the solenoid if you don't want to spend the money on a starter.
Old Dec 26, 2004 | 10:56 PM
74FLCONV's Avatar
74FLCONV
Well...the starter looks old...after going through the removal process, I'm probably going to stick one of those mini-starters back in.
Thanks,
D. Ocean
Miami, FLA
To Bench testing starter?
