Engine Storage
Old Dec 27, 2004 | 08:05 PM
glen242's Avatar
glen242
Default Engine Storage
Going to do an engine swap this winter and I want to keep the original engine. What do I need to do before I put it to bed for a long time? It will be on an engine stand and covered with one of those plastic engine bags and stored in my laundry room.
Thanks,
Old Dec 27, 2004 | 08:15 PM
joe73vette's Avatar
joe73vette
Before you pull it, change the oil and add a quart of STP or similar product. Then warm it up and spray some "fogging oil" down the carburetor until it stalls. Drain the fresh oil and the water from the block. Remove the gas from the carb and fuel pump if they are going into storage too. Unscrew the rocker arm nuts to close all the valves. Put a couple of big dessicant bags in the plastic bag, too. Joe
Old Dec 27, 2004 | 09:55 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you know laundry rooms can have alot of moisture in them...you may want to keep an eye on it....
Old Dec 27, 2004 | 10:08 PM
glen242's Avatar
glen242
Thanks for the tips. What is and where can I buy "fogging oil"?
Thanks,
Old Dec 27, 2004 | 10:28 PM
joe73vette's Avatar
joe73vette
Thanks,
Fogging oil is a marine product - it comes in spray cans, and sprays as a foam that dissolves into sticky oil on the cylinders. NAPA might sell it, or a marina/boat store. Joe
To Engine Storage
