Door Problem
I have the same problem a lot of you guys have in that on occasion my door will not latch when closed or will not unlock when locked. I seem to always get it open by the flicking of the inside handle method and I have been told the problem is a "worn out spring".
And now for the ?
where is this mystery spring in the latch or handle mechanism, How do I fix this problem?? If I go to remote locks will it solve the problem or make it worse??
H E L P !!!!!!!!!!!!!!!!!!
And now for the ?
There is 30 years worth of pushing and pulling on those linkages. You will be amazed at how well everything works once it is set up again at the correct lengths. No secrets just get in the door look at each linkage and adjust the length until it does what it is supposed too. Before I adjusted mine the door handle would hinge almost all the way down before it would start to engage and I would have to yank on the door to open. Now I can press about 20% down with two fingers and it pops open like a new car.
Now go fix it!
Cheers,
Pete
