#2 body mount ?
Old Dec 28, 2004 | 08:06 PM
bams12's Avatar
bams12
Default #2 body mount ?
Starting from the front on my 1980 vette I cannot find the #2 body mount. I have the car on jack stands and I thought I would put some penetrating oil on all the mounts. Cannot seem to find those #2 mounts. Any advise or am I missing something . Thanx Brent
Old Dec 28, 2004 | 08:20 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You get to them from inside the car, remove the plastic panels in front of the doors.
This might help:
http://forums.corvetteforum.com/showthread.php?t=976790
Old Dec 28, 2004 | 08:47 PM
bams12's Avatar
bams12
I was able to get at the one through the black plastic louver in front of the door. I thought that from the aim that I there should be a mount between the one in the black plastic louver and the one in the rear wheel well that I took the little metal cover off of. My aim shows it about midpoint of the door. Thanx Brent
Old Dec 28, 2004 | 09:08 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Download this file:
http://NHvette.com/ftp/Body_mounts_small_file.pdf
and here's the overview:
Number1 is at the firewall, accessible from under the car. Number 2 is right where your (or your passenger's) feet are. Number 3 is behind the metal plates in front of the rear wheels. Number 4 is behind the rear wheels.
Hope this helps
Old Dec 28, 2004 | 10:03 PM
bams12's Avatar
bams12
Thanks for the reply. I have that same diagram in my assembly instruction manual . I guess I will have to look a little harder or get my wife to find it . lol Thanx Brent Upon looking at the diagram a little more closely and comments , do you have to pull the interior carpeting back to get at it.
Old Dec 29, 2004 | 09:29 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You have to pull the carpet back to access #4 - this silly square plate (retainer nut) will most likely brake off because it's only spot-welded....
Here are photos of #1 thru #4 :
#1 driver side
#2 passenger side
#3 passenger side
#4 driver side
Old Dec 29, 2004 | 10:11 AM
Edzred72's Avatar
Edzred72
Very nicely done pics. Great job RedBad!!
Eddie
Old Dec 29, 2004 | 10:13 AM
bams12's Avatar
bams12
Now It all makes sense , Thanks again . You saved me alot of screwing around trying to find #2 mount . Brent
To #2 body mount ?
