Painting trim pieces
"When I use spray paints I never achieve that flat smooth surface appearance. I always get that bumpy "orange peel" look no matter what brand I use. How does the factory paint trim items or for that matter how does anyone paint a metal object and get that smooth glossy appearance without color sanding and buffing for hours. Case in point the file cabinet in my office is gloss black and smooth. You can't tell me the file cabinet company has a body shop that buffs file cabinets during production. How is this done?"
If your using a detail gun or air brush try using more thinner/reducer to allow the paint to flow better, but apply light coats so as not to run it. With more thinner your are more likely to run. Spray each portion of the surface while that paticular portion is laying flat. When i paint my car the hood always looks the best because you can lay a nice wet coat and it will flow out and yet not run.
P.S. There is no way you are going to achieve the DOI (Distinctness of Image), and overall quality with a 5 dollar can of Krylon. The urethane automotive paints costs around 100 bucks a quart.
I have found epoxies and some enamel gives me that smooth shine because the longer drying time of epoxy allows it to flow and settle better. The surface needs to be sanded and prepped properly and most times I used 3 coats primer with 600&1000 grit wet sanding in between all coats. This made the surface smooth for final paint. JMO
I had vary little trouble with my interior restore I just finished, but I did paint all THE PARTS in my vary cool and air-condition basement (my wife complained of the fumes but hey IT'S HER VETTE)
