73 Big Block
Is a Big Block going to require alot of changes to the compartment... Like rad/mounts/suspension etc...?
Please let me know if anyone has done this... as I'm considering going 383 stroker... It is something I'm considering.
I just finished my swap in October. You can find more infor at my site below, but briefly, I changed the radiator to BB aluminum, plan on changing the front coils, and needed all new BB pulley's. With a '73, you may not need a new hood. Motor mounts are the same, starter is different, but I upgraded a lot of items too.
It wasn't cheap, but well worth it, I did a little more than a simple engine swap though. I built mine completely from scratch and only the crank & rods are "stock."
454 Rebuild Page 454 Installation
I transplanted a 454 into mine in place of the original 350. Yes, there are things that you will need to change...but to address the ones you asked about: The radiator was the same for either the 350 or 454 in 1973. (use 1974 hoses...the lower 454 hose configuration for a 1973 will cost you, in 1974 it went to a 1 piece set up) You will need to change the front springs...the 454 is a little meatier than the 350. I replaced the engine mounts, but they were dirt cheap, so not a factor. Something to consider though...ALL of the accessory mounts are different. By that I mean, Alternator, PS Pump, A/C mounting brackets, AIR pump (if you have it), as well as all of the pulleys. Some of that stuff can be pretty pricey, but all can be had. Keep in mind though, you need to get "CORVETTE" only accessory brackets...VERIFY the correct PN's. Everything on a vette is a "Low-V" configuration, so that everything fits under the hood. Although other BBC brackets will bolt up, you won't be able to close the hood is you use stuff from a pick-up, Chevelle, etc....
If you'd like to talk more on this, feel free to email me: suburbandave@hotmail.com
Dave
