Building a Bulletproof IRS
Old Jan 13, 2005 | 05:56 PM
helix60's Avatar
helix60
One question regarding the modifications required.
The article refers to a series 4 case, are they refering to the differential case or the carrier unit?
Thanks in advance,
Heli
Old Jan 13, 2005 | 06:38 PM
Gordonm's Avatar
Gordonm
The carrier unit. It is what the ring gear bolts to.
Twin_Turbo's Avatar
Twin_Turbo
the carrier, the 4 series will accept a higher ratio than the 3, with the 3 and a spacer (or a thicker ring gear) you can't get into 4s
Old Jan 14, 2005 | 07:08 PM
helix60's Avatar
helix60
Thanks I know what the carrier is. Actualy I should have asked if i could use any 63-77 IRS vette differential unit to start with. And install the 12 carrier unit after modification. I've got a few 12 bolt posi carriers lying around.
Regards,
Heli
To Building a Bulletproof IRS
