Deck Height
Old Dec 30, 2004 | 09:13 PM
Oldguard 7's Avatar
Oldguard 7
Default Deck Height
Can someone explain what deck height is and how to measure it.
I would like to caculate my compression ratio for the current set
up I have and what it would be with different heads.
Old Dec 30, 2004 | 09:54 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i'm out of town and i can't reference this....but since no one is chiming in i think its the distance between piston TDC and the top of the cylinder block....where the gasket would go in between head and block....measure it by moving piston to TDC and put a straight ruler across the cylinder and measure down....then use a volume formula to calculate volume...something llike distance x diameter (check this formula can't remember for sure) then you take head volume and add something for gasket thickness apply a formula an voila you have an answer....clear as mud.....
Old Dec 30, 2004 | 10:02 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
If the piston is siting down in the cylinder, below the block deck, then the piston is "in the hole." That would be taken as a negative number....ie.. -0.005
Level with the block deck is "zero" (0) deck.
Old Dec 30, 2004 | 10:10 PM
442olds's Avatar
442olds
deck height is the distance from the crank centerline to the top of the block. This uses a special tool to measure it precisley. The other measurement you need is the length of the rotating assembly which is the 1/2 the stroke + connecting rod length + the compression height of the piston (distance from wrist pin centerline to top of piston)
You subtract these two dimensions and add the gasket thickness to get the quench height.
Typical Deck heights for the small block is 9.025 and the big block is 9.8. But you should have a machine shop check the deck and make sure its flat. They may have to cut a few thousands off the top which will affect your calculations.
Download this spreadsheet and enter everything in the that is colored yellow, http://www.et-motorsports.cc/tech/en...uild_sheet.xls
Good luck.
Old Dec 31, 2004 | 11:43 AM
stingr69's Avatar
stingr69
The dimension you desire is measured with the piston at top dead center. You need to measure down from the top of the block to the top flat surface of the piston you are going to be using. This dimension is used to calculate static compression ratio. It can easily vary from one cylinder to another depending on the tolerance of all the pieces but you are striving to have them all the same.
-Mark.
Old Dec 31, 2004 | 11:48 AM
EDDIEJ82's Avatar
EDDIEJ82
Another forum member gave me an easy way to measure how far the piston is from the deck.
Lay a straight edge across the bore, and measure with feeler gauges when the piston is at TDC
To Deck Height
