pinion angle question
Old Dec 31, 2004 | 02:45 PM
xxxl68's Avatar
xxxl68
Default pinion angle question
I need some help here.
Some backround info I've got a 68 vert comming close to finishing up my frame off resto I've been working on this car for about 2 1/2 years and I'm starting to see the light at the end of the tunnel.
I just finished installing my rear suspension (new T/A, vbp composite spring, new half shafts, shocks, dragvette set up, rebuilt diff 4.56).
Now I'm about to install a new viper t56. I did not get a kiesler set up, however I have everything thing I need for the install except the removable crossmember which I'll do myself.
My question is what's the easiest way to find the right height and angle of the transmission. I know the angles should be equal but opposite. Should I measure the the angle and height of the diff. than fab up the tranny mount to match it?
Also the body is off the car everything is accessible.
Any help here would be appreciated.
Thanks,
xxxl68
Old Dec 31, 2004 | 02:48 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Not sure of the BEST way but they do make pinion angle toos.
Also I want to say don't forget the side to side angle. If the diff is not perfectly square you will get vibration too.
Old Dec 31, 2004 | 03:09 PM
Schmucker's Avatar
Schmucker
Just buy an angle finder and put it on the pinion. I did mine the opposite way, I took the angle off the transmission and changed the differential to match it (custom crossmember). There is only about 1-2 degrees so it isn't really too much of a difference. It is basically a straight shot.
Old Jan 2, 2005 | 03:51 PM
xxxl68's Avatar
xxxl68
ttt
xxxl68
Old Jan 2, 2005 | 04:20 PM
norvalwilhelm's Avatar
norvalwilhelm
Side to side is also important. With the body off it is difficult to set the angle. I know this is opposite to what evertone things. When installing the transmission and building custom mounts I always push the transmission as high a possible, just so the top clears the tunnel but not by much. I do modify the hole for the shifter to allow the transmission as high as possible. I then us a magnetic protractor and measure off the yoke.
This is a down angle, I then check the pinion and make it equal up which is easy by making the rubber puck thinner or thicker, but mainly thinner.
I also string the car. A string from the center of the damper to the center of the rearend and check alignment off the transmission output and pinion to make sure it lies in this plane.
Mine did not and I ended up taking the rearend out, slotting 3 or the 4 holes, rotating the pinion until it lined up , filling in parts of the old holes and moving 3 of them for better alignment.
I had a vibration problem and this totally cured all vibration.
I also have a special homemade tool that goes on the pinion flange with a pointer, one end rides in the center of the pinion, the little center drill mark and the other end is the correct length to almost go in the back of the transmission yoke.
Both alignments are critical.
With the body off how high do you make the transmission????
Old Jan 2, 2005 | 04:28 PM
70 LS1's Avatar
70 LS1
It doesn't matter as much in a car with a solid mounted differential such as ours. I eyeballed it and have had no vibration problems at all. I am sure I will get flamed for being a "bubba", but who cares.
Much more of a concern in a live axle car where the driveshaft actually changes angle.
Old Jan 2, 2005 | 04:32 PM
norvalwilhelm
I don't like to gamble. I would rather cover my bases.
Gambling is for someone who doesn't care if they win or loose.
Old Jan 2, 2005 | 04:39 PM
427V8's Avatar
427V8
Gambling not allowed...
To pinion angle question
