Turn signals not working..Why????
Old Jan 3, 2005 | 10:07 AM
72Shark's Avatar
72Shark
Default Turn signals not working..Why????
Now that my state inspection is due, my turn signals won't work. All my bulbs are good, and they light up brightly when I put the signal on, but they don't do the "on an off" thingy. I've checked and rechecked the bulbs and all is good. They worked about a month ago when I put her in the garage and I've never had this problem. Could it be the "switch" in the steering column? (and if so, how hard to change??) Any suggestions?
Old Jan 3, 2005 | 10:15 AM
Martin72's Avatar
Martin72
Probably nothing more than the flasher.
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
did you check your flasher...it's usually located in the fuse panel...
edit...Oh the humanity, beat out by seconds by Martin72....
Old Jan 3, 2005 | 10:20 AM
Milest's Avatar
Milest
There is also a flasher behind the map pocket on the passenger side. Might chech that as well. Good Luck.
Old Jan 3, 2005 | 10:25 AM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
My '72 did the same thing but just on one side. Turned out that the signal housing needed to be grounded better. If both side at once on yours, probably flasher.
Old Jan 3, 2005 | 11:22 AM
72Shark's Avatar
72Shark
THat would be so cool if it was the "flasher"!!! I did find one of the springs from the "turn signal cam" thingy that had fallen loose and was just laying in the column. replaced it. Now I'll check the flasher!! Cross your fingers!
Old Jan 3, 2005 | 01:57 PM
Todbo's Avatar
Todbo
I think the turn sig flasher is on the pass side
Old Jan 5, 2005 | 04:49 PM
72Shark's Avatar
72Shark
$1.98 later, the turn signals work!!! It was the "flasher" as predicted above. Cool...and THANKS!!!!
To Turn signals not working..Why????
