With wiper door open, I hear a loud click when I turn wiper switch on but wipers dont move and motor is not spinning. Slow or fast position makes same click noise. It just worked fine a week ago.
Anyone know if it's bad switch or motor? I checked grounds which look alright.
There is a button type switch on the firewall near the passenger wiper arm.. The door has a piece on it that must "make" this switch when the door is open. Mine broke a wire on the switch once. This switch won't allow the wipers to operat until the door is fully open.
[QUOTE=Surfer69]I know the switch and I think it is a vacuum relay type. I looked at it and it looked fully depressed with door open.[/QUOTE
There is another electrical switch along with the vacuum relay. It is on the firewall with a red and white striped wire... I realize you solved the problem.
