man! im insanely jeolous. that engine in a vette no less. dude you over compensating for something! i just put that as my background, hope ya dont mind!
I think mike has short legs and can only depress the accelerator 1/8th of an inch, so he needs a terrible amount of power to get at least some decent power w/ 10% max throttle action
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's pretty cool, :cook: gonna scare the competition off the start line. How did you put the "632" in the valve covers and were you thinking of laying in some enamel for color ?
Car has been 7.50 at 187mph. This is a new combo for more power.Actually now 640 cubes by way of 4.75 sonny bryant crank,with 4.625bore.8.75 je blower pistons on grp alum rods.custom arp 2000plus rod bolts,crane roller .847 lift 280 290 duration cam running on solid steel rollers. Brodix m24xtra cnc heads with 390cc runners flow over .475cfm at .800lift.Jesel shaft rockers,msd crank trigger. 10qt pan, BDS HI HELIX billet rotor 14-71 supercharger with 1350cfm dominators with custom buzzardcatcher air plenum, runs thru 2and half inch primaries to 5inch collectors to custom stainless 5 inch sidepipes.mainly drag car but sees light street cruising to wake the neighbors and scare the ricers. By the way its in a 73
I'm building a blower motor as we speak, although nowhere near as stout as yours. It is a big block, however, and I'm curious about clearance between radiator/fans and if you will drive PS or an alternator.
