door handles
Old Jan 4, 2005 | 06:33 PM
Musclecarmaniac's Avatar
Musclecarmaniac
Default door handles
My door handle "flap" return spring feels week, like it does not return the flap into proper position. I looks like to fix this the door panel has to come off. Any tips on fixing this? The skin panel is already off.
Old Jan 4, 2005 | 06:52 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
2 ways to fix this. There is available a springy metal thing that pops under the flap that holds it in the up position. Can be done without removing the door panel. I pulled the handle in mine and replaced the spring itself which had broken. That requires pulling the panel.
Old Jan 4, 2005 | 07:19 PM
john1977's Avatar
john1977
Just like mako72 says,springclip under the handle or pull the door panel.Pulling the panel is easy but getting to the rear nut that holds the handle can be frustrating to say the least.
Old Jan 4, 2005 | 07:39 PM
Z-man's Avatar
Z-man
I fixed my driver's side handle with one of those springy things about 20 years ago and it has worked perfectly ever since. It takes about 3 seconds to install.
Old Jan 4, 2005 | 07:51 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
The spring in mine died last year, so instead of using the flap spring, I changed out the handle assembly. If you decide to go through that route, the best thing i can tell you is to be patient, take breaks if it's stressing you and buy a pair of the long nose needle nose pliers. they are worth their weight!. If you drop anything, take the window motor panel off and you can reach through that way...
Old Jan 4, 2005 | 08:19 PM
David Ey's Avatar
David Ey
Not trying to rob your thread but......
Both of my outside door openers are hard to operate with just one hand.
The springs are ok. and the mechinisms have been removed and cleaned.
The paint guy who removed and reinstalled em said no lube...it would just attract dirt. But they are still hard to operate.
Any Ideas?
Old Jan 4, 2005 | 08:24 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
mine did that too and i sprayed the latch mechanism from the outside and the inside... works great now...
Old Jan 4, 2005 | 08:49 PM
WESCH's Avatar
WESCH
Hi
You can always use dry lube, like silicone or molicote spray.
Gunther
Old Jan 4, 2005 | 09:10 PM
Musclecarmaniac
So where can I find this "springy thing"? LOL
I always look for the easy way out.
Old Jan 4, 2005 | 09:28 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
pretty much any of the supporting vendors should have them. i know i have seen them in more than one catalog... (Michael Waltrip, eat your heart out when it comes to pimping out sponsors!) lol
Old Jan 4, 2005 | 09:52 PM
CrossedFlags77's Avatar
CrossedFlags77
I have an extra spring laying around that I dont need. If you want it say the word and its yours. All I need is your address.
Old Jan 4, 2005 | 10:00 PM
Musclecarmaniac
Wow thanks! Check you PM!
To door handles
