Flexplate/Converter question...
Old Jan 4, 2005 | 09:41 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Flexplate/Converter question...
I just put the converter on top of the flexplate and the holes on the flexplate that line up with the converter are a little bigger than the bolt width (by 1/10 inch).. Is it supposed to be like that??
Old Jan 4, 2005 | 09:59 PM
markdtn's Avatar
markdtn
The holes in the flexplate are a bit bigger than the TC bolts. I don't know exactly how much, but the TC bolts typically have big heads, I wouldn't worry about it.
Old Jan 4, 2005 | 10:11 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Old Jan 4, 2005 | 10:42 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Stupid question. Are you using metric bolts in the new convertor?
Old Jan 4, 2005 | 11:15 PM
GrandSportC3
Thanks!!
Old Jan 4, 2005 | 11:23 PM
Schmucker's Avatar
Schmucker
I want to say they should be 15mm long, M10-1.5
Old Jan 5, 2005 | 12:20 AM
GrandSportC3
The bolts came with the converter....
Old Jan 5, 2005 | 12:29 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
we had no problem with putting the TC bolts through the flexplate and lining them up....so i would suspect that we had holes that were slightly larger also...funny thing was all of the flexplate bolts from the speed shop were too short for my satisfaction....they only had about 1/8 bite into the TC threaded mounts.... i purchased grade 8 bolts that used up all the "thread space" from Lowes
Old Jan 5, 2005 | 12:34 AM
GrandSportC3
Luckily my bolts were supplied with the tranny...
To Flexplate/Converter question...
