Transmission
Old Jan 5, 2005 | 04:22 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Transmission
Hi I have a 75 L-48 Coupe with a automatic transmission. I am not sure which transmission my car has. My car has transmissoin fluid in it but it still will not work right. The car shifted fine until today when I got in it. The car has to be reved and set for a couple of seconds before it goes into reverse. Thenk when i put it in drive it does it some times. When I drive it it takes a while to shift into second you have to wind the car to about 3600 upward rpms and it will shift in to second and them eventually third. Do i need to rebuild my transmission or is it something simple. Thanks.
Old Jan 5, 2005 | 04:31 PM
carl a's Avatar
carl a
-its should be a th-400 ,,,,i wouldnt drive it,,. could just be the pump going out. take it to someone you trust!!,or you'll be paying for a re-build
Old Jan 5, 2005 | 04:45 PM
Silver00V6Camaro
what pump? I am redoing the cr so it will be awhile before I can take it to a shop. The car is drivable but just around the block because there is no windsheild or lights. I am just driving it to make sure it does not get any stress cracks. The transmission has a leak from the pan because the car has been setting for so long. I filled with fluid and it started shifiting fine. Then today I will not. So why would it go out overnight with me not even driving it.
Old Jan 5, 2005 | 06:23 PM
Silver00V6Camaro
ttt
Old Jan 5, 2005 | 07:12 PM
redwingvette's Avatar
redwingvette
If it is a th400 then check the vacuum line going from the intake manifold to th trans. If the hose is drie and cracked it will not shift correctly.
Old Jan 5, 2005 | 07:24 PM
71coupe's Avatar
71coupe
That would be the first thing I'd check. Also, when you check the fluid level, make sure it's fully hot - like driving on the freeway for 20 miniutes hot. Overfilling can be worse than being too low.
Old Jan 5, 2005 | 07:30 PM
fast idle's Avatar
fast idle
could you please explain how driving a car prevents stress cracks??
over years the filings from wear on the tranny will build up and plug the filter.you can remove the pan and replace the filter. if it works , fine for now, if not , it may be the pump.in either case the rebuild will be in the future.
you can gain 20 h.p. + or- by turning the 400 into a planter and get a th350.
Old Jan 5, 2005 | 07:48 PM
carl a's Avatar
carl a
the pump is what pumps the trans fluid. that pump. no pump, no pressure, no go...
Old Jan 6, 2005 | 07:00 PM
Silver00V6Camaro
When you mold a new front end and rear bumper on you don't want it to crack therefor you test drive to make sure it is not going to crack before a lot of money is spent on paint. Considering my paint job alone not the body work is going to be about 2500 bucks my cost since I own a bodyshop. It is also a good way to make sure you molded the front and rear ends correctly.
To Transmission
