max compression
Old Jan 6, 2005 | 09:32 PM
greyghost79's Avatar
greyghost79
Default max compression
what's about the maximum compression ratio you can run with a carb and still run on street with pump gas (93 octane)?
Old Jan 6, 2005 | 09:38 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I've heard of 11:1 on 93 octane with aluminum heads......
Old Jan 6, 2005 | 09:47 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It actually has a lot to do with the cam you are running and it's duration/overlap but for something with a mild cam with a aluminum heads
I agree with the post above 11:1 CR is a good limit to impose on yourself when building a motor. Mine runs on 91 but I have a fairly big cam
Old Jan 6, 2005 | 09:55 PM
C3 Stroker's Avatar
C3 Stroker
Mine has 11:1 CR with aluminum heads & is OK with 93,(barely) & 230 deg. @ 0.50" hyd. roller cam.
Old Jan 6, 2005 | 10:07 PM
EDDIEJ82's Avatar
EDDIEJ82
Motorheads right, compression is only one component of an engine. A well thought out engine can handle a lot of compression on pump gas or visa versa one that is randomly thrown together by picking stuff out of a cataloge can ping at 10:1
Cam overlap, piston head shape and material, combustion chamber shape of the heads and head material, piston to head quench, timing and timing curve, and carb. jetting all have a very definate impact on how much compression you can get away with on pump gas.
I'm running 11.94:1 and it will run on 93. I have to richen the carb and turn the timing back a little but it runs fine on 93. You just have to think about how everything works together.
Old Jan 6, 2005 | 10:35 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Mine's a 10:1 aluminum headed 355 with 230@ 0.50 and I could'nt get it to rattle if you paid me....
Old Jan 6, 2005 | 11:05 PM
MotorHead's Avatar
MotorHead
Another thing that is overlooked alot is the vacuum advance. That can advance you timing into the 50 -55 and more degress. I have never run one and never had any pinging problems. My last 355ci had 10:1 CR with iron heads and the crankiing compression was 230psi across the board and I ran 40deg advance on 93 octane no problem.
Also when I first put my 406 motor in I set the timing but with all the crap going on the distributor must have got bumped a little because when Lars looked at it a few days later he said it was set at 45deg advance at 3000RPM, that's with 11:1 CR and aluminum heads. If I was running a vacuum advance I bet there would have been alot of pinging
Old Jan 7, 2005 | 03:05 AM
redc3's Avatar
redc3
i was gonna make a lucid comment, but i see its already here!
Old Jan 7, 2005 | 03:42 AM
Schmucker's Avatar
Schmucker
One guy in the first Engine Masters had 16:1 compression.
To max compression
