Vacuum Line Kit
Old Jan 7, 2005 | 08:54 AM
VaporLockd's Avatar
VaporLockd
Default Vacuum Line Kit
I'm to the point where I think it would probably be in my best interest to replace all of the vacuum lines on my '70. I thought I'd ask here if any of you know of a package that includes all the vacuum hoses and where would be the best place to pick it up.
Thanks in advance,
VaporLockd
Old Jan 7, 2005 | 08:57 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Several of the supporting vendor here offer kits and they're (kits) probably the easiest.
When I replaced all of mine, I just went down to the local parts store and bought vac hoses - cut my own lengths...
Old Jan 7, 2005 | 09:00 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I did the same thing with mine. Its not really too bad of a job. Most of the corvette parts warehouses will have the kits. You might give Volunteer Vette a look and also try The Last Detail. There are may schematics on the net that show the hose routing.
Old Jan 7, 2005 | 09:09 AM
68BLUEVETTE's Avatar
68BLUEVETTE
I have a spare kit that came with my car. Not sure what the going rate is, but if you would like it, I would be more than happy to send it to you. PM me...
Old Jan 7, 2005 | 09:25 AM
desi's Avatar
desi
Old Jan 7, 2005 | 11:04 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i thought about it and wanted the color striped hoses because they look cool....Corvette Central Deluxe kit for 79.80 came with new fittings, filter, good instructions and diagram, etc..
[IMG][/IMG]
Old Jan 7, 2005 | 11:10 AM
lvrpool32's Avatar
lvrpool32
Dr Rebuild sells the best kits IMHO. The hoses are the right ID and OD and they have the correct molded ends where necessary.
Nick
Old Jan 7, 2005 | 11:30 AM
Stewart's74's Avatar
Stewart's74
I'd go with the Doc Rebuild kit too.
Old Jan 7, 2005 | 11:44 AM
CGGorman's Avatar
CGGorman
I installed a kit from the good Doctor a couple months ago. It had all the fittings, molded ends, and diagrams. Installed and on the road in two hours with NO cussing or bloody knuckles.
Old Jan 7, 2005 | 11:47 AM
bobs77vet's Avatar
bobs77vet
including the new firewall grommet and hoses to the headlight switch and pull down switch?...and no cussing ... come on now you don't expect us to believe that do you?
Old Jan 7, 2005 | 10:08 PM
VaporLockd's Avatar
VaporLockd
Thanks y'all!
Vaporlockd
To Vacuum Line Kit
