spark plug wire #?
Old Jan 10, 2005 | 03:02 AM
memLT-1's Avatar
memLT-1
The Even Numbered Cylinders Are On The Right 2 4 6 8.odd Are On The Left Side Of The Engine 1 3 5 7
Old Jan 10, 2005 | 05:45 AM
Ybnormal's Avatar
Ybnormal
I posted a picture here that I got from one of the forum members www.angelfire.com/al/swhite7/temp.html Hope this helps
YBnormal...drive a vette
Old Jan 10, 2005 | 06:40 AM
Secret Squirrel's Avatar
Secret Squirrel
Originally Posted by greyghost79
got a pic?
Here 'ya go
Old Jan 10, 2005 | 09:10 PM
kdf1986's Avatar
kdf1986
The plug by the vacuum cannister should be the number 8 plug.
What is also important is what plug wire does the rotor align to for the proper firing sequence. If you know where the number 1 cylinder is at top dead center or compression stroke, then the relationship to this rotor position and the distributor tower where the access to the points and dwell are should be the number 1 spark plug wire, and going clockwise, the #8 plug wire would then be above the vacuum advance cannister.
kdf
Old Jan 10, 2005 | 09:20 PM
greyghost79's Avatar
greyghost79
mine is an HEI ignition. shouldn't the number 1 wire be on the terminal just to the right (clockwise) of the "protrusion" on the cap for connecting the module, tach, etc.???? if so, wouldn't that put the number 4 wire directly by (behind) the vacuum canister???
Old Jan 10, 2005 | 09:42 PM
C3 Stroker's Avatar
C3 Stroker
Determine your #1 plug position by the rotor position pointing on the compression stroke (finger on the spark plug hole method). Where it points is YOUR #1. It can be any position on the cap ....it's only in the "usual" place for convenient placement of the vacuum advance. It can be in ANY position. From your #1, go clockwise in rotation....doesn't matter if HEI or not.
To spark plug wire #?
