DeWitt Radiator Fitting
Old Jan 8, 2005 | 12:29 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default DeWitt Radiator Fitting
Question for someone smarter than me... probably a lot of you...
I just replaced my stock radiator with a DeWitt direct replacement. Had no issues with mounting my SPAL fans to the new radiator, however, my top radiator support brackets don't fit as tight as they did on the original radiator. Did others experience this? Any ideas on how to tighten things up so that it doesn't rattle around?
Old Jan 8, 2005 | 10:03 AM
Tankers's Avatar
Tankers
Mine did the same, I replaced the rubber inside the brackets, that helped some. I also ever so slightly bent the brackets down some and installed. My radiator does not move at all.
Old Jan 8, 2005 | 10:28 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Check to make sure your core support is'nt weak and rotting, otherwise it causes a "drooping radiator". Noticed on the '80 I used to have the top of the radiator was barely in the top cushions-that was when I noticed "how rotted out my core support was".
Old Jan 8, 2005 | 12:12 PM
markdtn's Avatar
markdtn
Yep, check your support. If it's OK, then replace the rubber-still available GM-and bend the brackets slightly.
Old Jan 8, 2005 | 01:34 PM
80TexasC3's Avatar
80TexasC3
Thanks!
Old Jan 8, 2005 | 02:41 PM
77Dream's Avatar
77Dream
Mine did the same thing and my rad support is in perfect condition. However the rad does not move and I don't see any future problems because of it.
To DeWitt Radiator Fitting
