Turn Signal Light?
Old Jan 8, 2005 | 02:08 PM
snakeman56's Avatar
snakeman56
Default Turn Signal Light?
I notice yesterday that the right turn signal indicator quit working, all the turn signal lights work fine. It just does not blink in the dash. What must I do to fix it.
Tom
Old Jan 8, 2005 | 02:20 PM
fast idle's Avatar
fast idle
probably the bulb in the dash.easy to change, hard to get at.
Old Jan 8, 2005 | 02:22 PM
snakeman56's Avatar
snakeman56
Thanks, that is what I was afraid I was going to hear.
Old Jan 8, 2005 | 02:25 PM
C3 Stroker's Avatar
C3 Stroker
Tom
It may just be the bulb needs replaced; loosen the dashpad to access it....if OK, check if voltage (12v) is present to the socket when signal is on....
To Turn Signal Light?
