Drilled/slotted rotors?
What type/brand are you running and what has been your experience?
I can't find an upside other than looks... I would NOT do it again.
None of the real performance brake mfgs recommend driling or slotting.
But if you only cruise around town and want to impress the ricers go for it.
. They should already be cast with the "holes" the casting otherwise they`ll start to crack. And i dont think the holes has much to do with weight but has its main purpose in helping the disc to cool,maybe
Anyway, "They" (whoever) claim it's for cooling and reduced rotating mass as well as pad scouring to combat glazing. In my experience, pad compound selection has more to do with braking performance than anything else. After that come fluid choice and maintenance. Get the right pads for your application. Racing pads AREN'T the best choice for street use, belive me. I've been through at least six pad iterations on the Lincoln and the best I've found for Hi-Po street use is a "club" or "autocross" compound that has good cold bite and moderate high heat (1000*) tolerance and still works when wet...Hawk, EBC, Performance Friction, and Porterfield all make good pads.
). First thing I noticed was that if they were soaking wet then the brakes would grab much quicker than they did before. This was a potential lifesaver on its own & was the main reason I did it. The downsides were that they'd eat brake pads (yes, I did chamfer the holes!), made a strange whirring noise when the brakes were on (the sound of my pads being eaten?), took more effort to slow down (less surface area?) & were severely weakened. I was riding down a resurfaced road that was covered with loose gravel. A car going fast in the opposite direction sprayed up a lot of gravel that peppered me. While it didn't hurt (fully dressed in the 70's safety gear of open face helmet, jeans, denim jacket & Zeppelin T-shirt!), or chip the paintwork, it cracked the rear rotor between 2 of the holes. The metal sprang slightly apart so that the next time I used the rear brake it was like dropping a boat anchor off the back. I stopped dead & it shredded the disc pad. Another downside was the rust that would form inside the holes & then spray all over me & the bike whenever it rained. If you've not got the problem of the rotors being exposed to rain (which you shouldn't with a car) then I'd say that it's not worth the trouble as the losses outweigh the gains. A friend got his rotors slotted and found that he had brakes immediately after getting on it in the rain (same as I did). He also found that brake pads were getting eaten & also found that he needed more effort to stop (something you may not notice with servo assisted brakes). Additionally, his rotors eventually warped badly. I'd spend my money on something more useful
The other 3 are the same.
I do not have a problem with eating pads.
There are lots of racing rotors full of through holes.
I must admit that slotted and cross drilled rotors look super. If you are just going to drive around and cruise they would work for you. If you are a very aggressive driver and are hard on your brakes I would not go this route. We have found that cross drilled rotors tend to develop heat pockets on them and warp or crack much easier than a rotor that has not been drilled on. So I guess it comes down to your driving style.
Tony
VBP
If I push down hard the car will stop me fast. Hence I am getting better tires and seatbelts so I don't leave an impression in the windshield.
The biggest difference I found though was the pads. Semi-metallic really stop you. They do wear out the rotors but what do I care I drove 1000 miles last year :-)
Will I notice any significant performance change?
Anyway I drilled my rotors, I think about 1/4 inch using a dividing head on the mill to get a uniform pattern.
I also turned the rotor on a lathe removing excess inner material, I hollowed out part of the hub. Each rotor lost 3 pounds, I weighed each one before and after.
I have never had a problem with cracking or permature pad wear.
Let's not overlook cost. There is absolutely NO comparison between a $2000 set of drilled Baer rotors and a $500 set of drilled "Chinese" rotors....You always get what you pay for.
I'm not stating an opinion when I say that I've had SERIOUS quality issues with drilled rotors. I've had two full sets of drilled rotors, each from a different manufacturer, on the same car. My driving habits don't change. The first set cracked severely (2" long cracks) in multiple places on three of the four corners after ONE drive. The second set has been holding on pretty good, but have developed irregular "divets" the size of nickels on the surface from warpage. They have not cracked and continue to serve me well, but I believe they have an inherent flaw in either the casting or drilling process or the interaction between the two.
Certainly rotors can be produced that don't have these shortcomings, but they must be carefully engineered and would have to carry a respective pricetag. My warning is to stay away from cheap (<$1000/set) drilled rotors.
They say the "Brutestop" rotor is for those who like to show.
They are reasonably priced at $52 rockauto dot com.
http://www.raybestos.com/usa/features/rotors.htm
After cracking my rear rotor I fitted a new one & left it stock, with the drilled one still on the front. I then went to Spain & rode through the Pyrenees with a passenger & luggage in the heat of the mid-day sun. The brakes were used a lot in the mountains and at the end of the day putting the front brake on lightly gave a pulsing feel. On investigation I found that the front rotor had warped badly, probably due to the heat. The rear rotor, which I use far more than the front (which is not how you're supposed to do it) was fine. Years later I went to the French Riviera with some mates & we rode through the mountains in the south of France. The roads were like those you see in James Bond films, or Ferrari adverts, so we camped up & spent the next day just riding up & down those switchbacks & crazy gradients as fast as we dared (no pillions). At the end of the day both my rotors had turned bright blue, but were still true. None of us had brake problems, yet some of the people were the ones that had also drilled their rotors 20 or so years ago (obviously they'd been replaced in that time!).
I'm not saying don't do it, I'm saying that if you do then pay attention to them for a long time after you've done it. C3 brakes, even when working correctly, aren't the best brakes on the planet, so do any modifications with care. If I was going to fit drilled rotors I'd also seriously consider some performance callipers as well. It'll cost, but how much do you value your life? Your life depends on how well the brakes work & while you can say "Oh, I never go fast enough to worry" it only takes one time for you to need excellent brakes when you haven't actually got them. I know this from experience, even at 47.36mph excellent brakes could mean the difference between life & death, if not of you, then of somebody else.
And, while Norval & a lot of other people here know what they're doing, there's going to be somebody reading who might think "Unsprung weight? Drilled rotors? Eureka!" & then goes & drills a sequence of 1/2" holes through their rotors. As for negativity, this is supposed to be a forum where people state their opinions & experiences. Mine weren't that good with drilled rotors. Maybe the Vette rotors are of a design/material/heat treatment where the same problems won't occur, but I'd wait for somebody else to try it & report back after a decent mileage has been done in all conditions eg. not just dry day driving at speeds of up to 55mph, but wet weather driving & high speed driving where the brakes are frequently used to bring the car down to low speed ie they might be fine at "normal" speeds, but will they be OK if one of us crazy Europeans, or some Texans, find that they need to stop quickly at 140mph (my wifes relative was killed in a high speed Vette wreck in Canada, apparently the brakes couldn't cope with the speed he was going at).
