C3 Question from a C4 guy
Old Jan 10, 2005 | 09:37 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default C3 Question from a C4 guy
Hey C3 guys and gals. I'm a C4 guy but am trying to expand my horizons :-) I have a customer with a '77 auto and am trying to find out the stock rear gear ratio for this car. I didn't see anything on the RPO codes to indicate a performance axle ratio option on this particular car, but if there was one available for that year, that information would be appreciated as well. Thanks!
Old Jan 10, 2005 | 10:02 AM
Crash80's Avatar
Crash80
I don't know if this will help.
http://corvetteactioncenter.com/specs/1977/77prod.html
http://corvetteactioncenter.com/specs/1977/77specs.html
Old Jan 10, 2005 | 10:04 AM
Solid LT1's Avatar
Solid LT1
More than likely a 3.08 Differential but, the bottom of the Diff center section is stamped with a code that will tell you or you can confirm with a simple check by rotating the driveshaft and see how many revolutions it takes to rotate the 1/2 shaft one turn.
Old Jan 10, 2005 | 11:10 AM
Schmucker's Avatar
Schmucker
AO = 3.08, otherwise I think it's a 3.70. Mine had a sticker on the top that said AO7. Probably can't see it with it in the car. Otherwise look at the stamping for the AO. It's probably an 3.08. Just take it downt he highway at 60mph. Check the RPM and compare with an online calculator.
http://www.idavette.net/tech/ratioc.htm Fill in the first three and click Compute Ratio.
Old Jan 10, 2005 | 11:32 AM
CorvetteZ51Racer
Thanks for the replies so far guys. The car isn't currently running, as we're putting together an engine/trans package for it. Just trying to get a handle on the ratio so we can match a stall converter for it. So the two possible ratios for that year were 3.08 and 3.70? I'll check it tonight to see if it has the performance ratio or not.
Old Jan 10, 2005 | 01:59 PM
PRNDL's Avatar
PRNDL
I don't know if you could get all of these with an auto trans, but according to my info there were 4 ratios available in 1977. Either way, the code will tell you which one you have. Possibilities are:
OA 3.08
OD 3.36
OB 3.55
OC 3.70
It is possible that one or 2 of those may only have been available with the muncie trans and/or L82 engine.
To C3 Question from a C4 guy
