'69 Underbody Heatshields
Old Jan 10, 2005 | 10:39 PM
marky mark's Avatar
marky mark
Default '69 Underbody Heatshields
I bought a pair of the new underbody metal heat shield reproductions now available. There are no instructions as to how to install.
Any suggesstions?
Thanks, Mark
Old Jan 11, 2005 | 05:11 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
In the front, they're bolted to the same bracket as the "footwell" shields on the firewall.
In the back, there are 2 brackets on each side riveted to the crossmember. The shields attach to those riveted brackets. Chuck
Old Jan 11, 2005 | 06:05 PM
marky mark's Avatar
marky mark
Thanks Chuck!
I should have known you would be the one with the answer. You've helped many of us over the years and I want you to know how much I appreciate the help.
Regards, Mark
Old Jan 12, 2005 | 07:34 PM
phclub's Avatar
phclub
New England Events Coordinator
Default underbody heat shield
Where did you purchase these, do they make them for the 70.
Old Jan 12, 2005 | 09:13 PM
marky mark's Avatar
marky mark
I bought them from Zip Products.
Maybe Zip gets them from Paragon perhaps. They are new so they aren't in the Zip catalog but they were in their on-line products "catalog". They sell the brackets needed separately.
I think the heatshields were a '68 & '69 only deal. I don't know that they would fit a '70 or later but don't see why not.
While you're at it, consider also adding the underbody insulation blanket which would add extra insulation from the heat.
Regards, mark
Old Jan 12, 2005 | 10:18 PM
rtpilot's Avatar
rtpilot
Got mine from Ecklers years ago
Old Jan 12, 2005 | 11:34 PM
marky mark's Avatar
marky mark
well I thought they were new. Guess not...
Thanks, Mark
To '69 Underbody Heatshields
