mystery motor
Old Jan 11, 2005 | 12:07 PM
cjs27410's Avatar
cjs27410
Default mystery motor
The motor is still in the car I dropped the pan to look at the botom end.
I am trying to identify some small block chevy rods from 1970-75. They have green paint on part of the beam. On the small end is 632 on some & 633 on others cast in. H- beam and have a thick seam.
Also, the pistons are marked TRW 202-99.
Any ideas?
Old Jan 11, 2005 | 12:22 PM
markdtn's Avatar
markdtn
My recollection for waht it's worth is that green dots are standard cast rods and pink dots were on the hi-po rods. Unless you are turning a lot of rpms or want like 500 hp out of it the standard rods are probably OK-particularly if you polish them and have them resized with good bolts. It's been a while, but that's what I remember.
Old Jan 11, 2005 | 12:25 PM
comp's Avatar
comp
H-beam or I ????
Old Jan 11, 2005 | 12:34 PM
cjs27410's Avatar
cjs27410
H-Beam with a thick seam.
Old Jan 11, 2005 | 02:26 PM
stingr69's Avatar
stingr69
ALL of the factory sbc rods are forged except for these later model powdered metal rods. The better ones had additional steps taken but all of them came from the same forging dies.
-Mark.
Old Jan 11, 2005 | 05:53 PM
BigBlockk's Avatar
BigBlockk
I don't believe Chevrolet ever put H beam rods in any of its engines. A thick seam means it's forged.
BigBlockk
Later.....
Old Jan 11, 2005 | 06:02 PM
markdtn's Avatar
markdtn
I stand corrected, thanks! Did not realize that for some reason.
Old Jan 12, 2005 | 03:28 PM
cjs27410's Avatar
cjs27410
My mistake these are I beam rods.
Old Jan 12, 2005 | 03:31 PM
cjs27410's Avatar
cjs27410
Any idea on the pistons?
TRW with 202-99 stamped on the inside.
Old Jan 13, 2005 | 03:06 AM
stingr69's Avatar
stingr69
Probably just an ID number for the piston blank.
If you can see the rear crankshaft flange or numbers on the crank, you can determine the stroke/size of the engine. Check the parting line on the crank to determine if it is a forged or cast crank. If the line is thin, it is cast. If the line is wider, it is forged.
-Mark.
Old Jan 13, 2005 | 09:35 AM
cjs27410's Avatar
cjs27410
Thanks for the info.
To mystery motor
